/ Harbor Freight Tools that don't suck #11,301
As California mentions none I've seen are not repairable. Buy a new whole light.
Yes ... our throwaway society. Don't fix it, toss it. Great for filling landfills earlier than necessary.
I'm not sure about that. I've had electricians here tell me that some of the cheaper ones have problems starting up the light in the cold. But most will start ok until it gets down to around 0 F degrees. Once it gets to -40 F, some of them have problems (but so do fluorescent lights).
I guess it depends on what you mean by "cold"?
I rarely get below Zero but all of my outdoor LEDs seem fine so far.
/ Harbor Freight Tools that don't suck #11,302
I have an overhead LED light that I bought at Sam's club. I think it's a Honeywell and I've had no problems with it in the cold out in the shop in my barn at any time of year.
/ Harbor Freight Tools that don't suck #11,303
I haven't even taken it out of my truck yet but, plan to give it a look over this afternoon and I'll report back. I'll need the bushings on a couple of implements and rest are Cat 1 / Cat 2 hitches. Found some pretty good prices, for the bushings on eBay.
The lower hooks are sized for Cat 3. This is a Cat 2 to Cat 3 bushing.
The opening on top hook is a bit less than 1 3/8” and there is better extension than on the old ones. I don’t think any of the “aftermarket” hooks would give much improvement.
Let me know if you have any additional questions.
/ Harbor Freight Tools that don't suck #11,304
Thanks! So HF has changed the spec since their first version which had a Cat 2 hook.
It seems to me using an adapter sleeve like that with a clevis to hold it in, is preferable to adding the semi-permanent adapters with rollpins on every implement.
/ Harbor Freight Tools that don't suck #11,305
There are LED bulbs that you buy to convert your existing fixtures but that's a whole different thread.... :thumbsup:
Double negatives are sometimes confusing. I think you are opining they are not repairable. ??
/ Harbor Freight Tools that don't suck #11,306
Thanks, Rick. Haven’t received mine yet. Don’t have the luxury to just pick one up☹️
I only intend to use mine on the FEL with quick attack mod. Think all my attachments are Cat I, so don’t know yet how I’ll address. Maybe change boom pole to Cat III as I never use on 3 pt. What is best way to go Cat I to Cat III on a temp basis? Thinking about my landscape rake.
/ Harbor Freight Tools that don't suck #11,307
I know this won't go over big with a lot of people here but I just run my cat1 stuff in the quick hitch without bushings.
So far I can't find any wear or damage to anything.
/ Harbor Freight Tools that don't suck #11,309
At that temp I wont care if it comes on I will be sitting by the fire😁
/ Harbor Freight Tools that don't suck #11,310
David, if your implements have draw pins for lower lift arms ..... you can replace them with Cat 2 draw pins (1 1/8" dia.) with Cat 2 to Cat 3 bushings.
CountyLine Draw Pin, Cat 1 to 2, S:p24TSC at Tractor Supply Co.
CountyLine Category 3 to 2 Lift Arm Bushing at Tractor Supply Co.
Total cost for both sides ..... about $20
Or install Cat 1 QH Bushings;
https://www.amazon.com/RanchEx-102074-Quick-Adapter-Bushing/dp/B0747GKLX8
If your implement draw pins are Cat 2 use these;
https://www.amazon.com/RanchEx-102076-Adapter-Bushing-Quick/dp/B01N9F3BLD
For your upper link;
CountyLine Category 2 to 1 Top Link Bushing at Tractor Supply Co.
https://www.tractorsupply.com/tsc/product/countyline-category-3-to-2-top-link-bushing
Hope this helps.
2008 Sea Ray 260 Boat w T/A Boat trailer (A59231)
2008 Sea Ray 260...
2010 CATERPILLAR 320DL RR EXCAVATOR (A60429)
2010 CATERPILLAR...
2008 Ford Ranger Ext. Cab Pickup Truck (A59230)
2008 Ford Ranger...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A60460)
2012 Freightliner...
2014 GMC Savana 3500 Cargo Van (A59230)
2014 GMC Savana...
