Pipe Threads #$%^&
/ Pipe Threads #$%^&
Because of where the fitting is and what I'd need to do to replace it, I was going to take it apart, clean it up, and try the 545 dope on it and see if it leaks. If it still does, then I'll have to replace a hose and several fittings.
/ Pipe Threads #$%^& #22
Just make sure whatever you use' that it is designed for the materials as well as product used within. (ie: stainless, iron, etc) I believe that if I remember correctly, it is 567 for stainless fittings.
2022 EZ-GO ELITE...
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
2000 Pro Stock Utility Trailer (A66285)
2000 Pro Stock...
New/Unused Quick Attach Auger (A65583)
New/Unused Quick...
Used Landpride GR1525 Stump Grinder
Used Landpride...
25in Wagon Wheel Chair (A65583)
25in Wagon Wheel...
