Sprayer for Brush Hog
/ Sprayer for Brush Hog #1
dumbarky
TC 48 Newholland
So I've been thinking about this for a long time. Have any of you guys ever put a spray tank on you brush hog? If so how did you set it up? I have a new 15 bat wing and seriously considering some type of setup. I believe this would cut down on trips across the pasture and improve my quality of forage. Any thoughts on this?
/ Sprayer for Brush Hog #5
I agree with not a great idea due to vibrations think would be easy to cause issue with nozzles. Also what is driving the sprayer pump, you have two ptos on your tractor or using hyd pump or electric? Then you have to adjust the spraying on the go due to tractor speeds dropping due to cutting loads. Also not good spraying weeds right after they are cut. Normally need a few days of growth before spraying and after spraying so chemical can be absorbed.
/ Sprayer for Brush Hog #6
The one thing I think it will get is low weeds like black berry vines.
However I don’t know about how the vibration would affect the sprayer components.
/ Sprayer for Brush Hog #7
I have seen sprayers mounted on mowers for folks doing right of way maintenance. Most of the time they are spraying a growth inhibitor to reduce the number of mowings they have to do. Not sure how well it would work if your not using a systemic herbicide such as 2,4-D, however if using a contact herbicide such as glyphosate then you would probably be OK.
/ Sprayer for Brush Hog #8
2,4D and glyphosphate both need to be applied to actively growing plants. I am not understanding how a sprayer on a mower accomplishes that. Putting either on a 4 or 5 inch stalk of a broadleaf will not kill it. Now if a residual herbicide is being applied that is a different story.
/ Sprayer for Brush Hog #9
The vibration may not be a big issue, I am only basing it upon my sprayer experience. I think the nozzles cap would tend to vibrate loose but could be wrong. However based upon my limited experience of spraying row crops and hay fields and such, often 20 inches is as near as nozzles are recommended to what is being sprayed and one reason is to give them distance to allow the spray to open up to the needed width. Then I certain don't know all the different types of nozzles and their specs. It certainly would not be hard to install a bar on the cutter to mount nozzles. Maybe boomless nozzles would work. Would be my recommendation.
Will you be mounting tank on the front of the tractor or a saddle mount off one side? Front end probably would give better balance. Depending on what you are mowing many need to protect the tank and any hoses.
/ Sprayer for Brush Hog #10
kthompson, do you think a 2,4D mix (like Crossbow) would work mounted on a mower to get weeds left after mowing?
I cut pastures at about 7-8" tall.
/ Sprayer for Brush Hog #11
I guess glyphosate to kill what you just mowed?
I was told that 2-4-D was best to use 11-14 days after mowing because it needed to be absorbed into the leaf. I was told it would be less effective if you mowed the leaf off before spraying.
/ Sprayer for Brush Hog #12
Glyphosphate is no different.
2008 Case IH 2152 Combine Header (A63688)
2008 Case IH 2152...
2007 Peterbilt 378 (A62679)
2007 Peterbilt 378...
ABI 80-ASRT-074 Command Seeder Tractor Attachment (A61572)
ABI 80-ASRT-074...
Lifts (A61567)
Lifts (A61567)
2008 SUBARU LEGACY 4 DOOR SEDAN (A64280)
2008 SUBARU LEGACY...
2015 Sealine F380 Flybridge Motor Yacht Boat (A59231)
2015 Sealine F380...
