Leave the 3 point loaded?
   / Leave the 3 point loaded? #1
def38
woods and mountains of Alabama
M-F 231S
When I'm through using an implement on my 3 point, I park the tractor with the implement in the air thereby loading the hydraulic system with the implement weight. Over night, (depending on implement weight) the 3 point will show some leak down over night (my M-F 231S is 2003 vintage). Before starting the tractor, I lower the implement to the ground. Is this a bad practice?
   / Leave the 3 point loaded? #2
I always let mine down when done, that way nothing can get trapped under it if it leaks down and nobody can accidentally let it down, if that were possible.
   / Leave the 3 point loaded? #4
Every component of your hydraulic system lasts longer if you dissapate hydraulic pressure when hydraulic pump is not operating.
   / Leave the 3 point loaded? #5
If it's okay to park it lifted, why would it be necessary to lower it before starting???
There is no safety issue. The tractor is always parked in a locked garage.
Jeff, my thinking has been that elastomer seals in the hydraulic system would benefit from being loaded against sealing surfaces when at rest. I'm wrong?
   / Leave the 3 point loaded? #9
Perhaps.
Tractor rubber, fabric and steel mesh hydraulic lines, subject to age and sun deterioration, are the most vulnerable hydraulic component of your tractor. My garage stored six year old Kubota has suffered two separate explosive and instantaneous failures of hydraulic lines to the FEL in the last two years.
   / Leave the 3 point loaded? #10
Well Rick, no I did not know that. That's why I asked.
I believe Rick thought the question so stupid that it must be a troll.
2013 LONE STAR TRAILER MFG. (A50854)
2013 LONE STAR...
2016 HITACHI ZAXIS 210LC-6N EXCAVATOR (A51242)
2016 HITACHI ZAXIS...
2005 Chevrolet C4500 Altec Bucket Truck (A50323)
2005 Chevrolet...
Case 721B (A47384)
Case 721B (A47384)
2003 STERLING ACTERRA 11FT FLAT BED (A51222)
2003 STERLING...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
