Leave the 3 point loaded?
   / Leave the 3 point loaded? #1
def38
woods and mountains of Alabama
M-F 231S
When I'm through using an implement on my 3 point, I park the tractor with the implement in the air thereby loading the hydraulic system with the implement weight. Over night, (depending on implement weight) the 3 point will show some leak down over night (my M-F 231S is 2003 vintage). Before starting the tractor, I lower the implement to the ground. Is this a bad practice?
   / Leave the 3 point loaded? #2
I always let mine down when done, that way nothing can get trapped under it if it leaks down and nobody can accidentally let it down, if that were possible.
   / Leave the 3 point loaded? #4
Every component of your hydraulic system lasts longer if you dissapate hydraulic pressure when hydraulic pump is not operating.
   / Leave the 3 point loaded? #5
If it's okay to park it lifted, why would it be necessary to lower it before starting???
There is no safety issue. The tractor is always parked in a locked garage.
Jeff, my thinking has been that elastomer seals in the hydraulic system would benefit from being loaded against sealing surfaces when at rest. I'm wrong?
   / Leave the 3 point loaded? #9
Perhaps.
Tractor rubber, fabric and steel mesh hydraulic lines, subject to age and sun deterioration, are the most vulnerable hydraulic component of your tractor. My garage stored six year old Kubota has suffered two separate explosive and instantaneous failures of hydraulic lines to the FEL in the last two years.
   / Leave the 3 point loaded? #10
Well Rick, no I did not know that. That's why I asked.
I believe Rick thought the question so stupid that it must be a troll.
2007 INTERNATIONAL 4200 SBA 4X2 DUMP TRUCK (A51243)
2007 INTERNATIONAL...
2016 Nissan Altima 2.5 (A50324)
2016 Nissan Altima...
2021 Case IH Magnum 240AFS CVX Connect MFWD Tractor (A50657)
2021 Case IH...
2012 Toro Greensmaster 1600 Walk Behind Mower (A48082)
2012 Toro...
2012 LEEBOY 8515B APHALT PAVER (A51406)
2012 LEEBOY 8515B...
2012 Ford Escape SUV (A50324)
2012 Ford Escape...
