Front Sweeper B7500
/ Front Sweeper B7500 #1
spirostats
NJ
2003 Kubota B7500 hst
Hi All
I have a 2033 b7500 hst tractor and I bought a used front sweeper and a quick hitch. For the life of me and after talking to messics and my local dealer and posting on another forum, I cant figure out the missing parts to make it all work.
Do any of you know what parts I need to compete the following installation? 2003 B7500 tractor to BX2537A sweeper through B2733A front hitch. The sweeper came with a front driveline male shaft that is too short (12") I measured about 19"-20" length needed. (or maybe I need a longer output shaft on the quick hitch?) Also the output shaft thats on the hitch measures about 17.5" and needs to connect to the rear PTO. I was told maybe the 44" part # 7060-02186 shaft would fit. Can anyone verify that or have any input on this?
Thank you
It's either 70060-02183 or 70060-02186.
Hi Diesel85
Thanks for your help and Sorry for the late reply.
I need two parts. I need to replace either the front DRIVE LINE - MALE PART that is too short or the output shaft that mounts to the hitch and then I need the driveline that connects the output shaft to the mid pto, Please see attached pictures when you get a chance
Thanks again man!
/ Front Sweeper B7500 #4
The shaft with the black plastic shield on it should have some telescopic length in it.
A driveshaft shop could lengthen your existing male shaft.
Dave M7040
/ Front Sweeper B7500 #5
Mid PTO to quick hitch shaft # on mine is B2734. The other shaft for the front on MINE is, BX2735, 1/2 shaft they call it. Good luck, Kubota sure does make this stuff CONFUSING.
Hi SwampCat. Ok it sounds like you have the same setup. I really appreciate the help. I would like to beg you to measure the parts you have.
I put the B2734 part on my cart. it shows up as 70060-04541. Ill wait to confirm before I order.
On the front 1/2 shaft ... I think I have that one but its too short. Even if I use the full telescopic length as DaveM7040 mentioned before. If you can measure all the parts you have I will at least be able to have a shop make them. Maybe its possible that my output shaft is too short (the straight one on the quick hitch that sits on the two bearings). If you measure everything I might be able to figure out where it fails.
Mine, from mid pto to implement measure as follows (approximations) mid pto >44" to > 17" output shaft to >23" to implement connection. Im calculating these lengths with enough play for normal operation and also room to lock the parts together.
I really think I have a short output shaft...maybe there is a longer one
/ Front Sweeper B7500 #7
I have the same quick hitch as you, I doubt Kubota made different legnth shafts for that. The mid pto shaft is also a fixed legnth, so that should stay the same. The front half shaft I have is for a BX2750C snowblower, so your sweeper MAY be different. Would gladly measure for you, BUT, I am 350 miles from my tractor.
Lol! 350 mile measuring tape will be hard to come by. I ordered part KUBOTA BX2735 HALF OF FRONT DRIVELINE. Will wait to receive and check fitment. I you _or someone else_ happen be able to measure by then I would appreciate the feedback. I will update this thread when I know more
Thanks again
/ Front Sweeper B7500 #9
Thank you
spirostats - I have a 2003 B7500 HSD-R that runs a B2781A snowblower through the B2733A Male Quick Hitch and Subframe. The Mid PTO Drive kit, from the subframe shaft to the mid PTO, is a B2734. Note the B2734 is a complete assembly which includes the P/N 70060-02186 Fixed Driveline and 24 other parts. My Half Driveline (Male Part), from the implement Half Driveline (Female Part) is a B2736. According to my Operator's Manual, The Half Driveline (Male Part) for BX implements, such as your BX2537A, is BX2735. Both the B2734 and BX2735 are "Wholegoods" which are ordered through the Sales Department at my Kubota Dealer, not through the Parts Department.
Best wishes!
/ Front Sweeper B7500 #10
spirostats - Any chance the person from whom you bought the sweeper and quick hitch might still have the B2734 and B2735 shafts? Or perhaps he/she knows who might have them now?
Hi Rusty
Sorry I've been away on business. I just got back and found UPS had delivered one of the parts. The KUBOTA BX2735 HALF OF FRONT DRIVELINE. It fits! Now I will try to figure out the mid pto driveline which according to "swampcat" is this one
https://www.messicks.com/ku/84496
part
DRIVELINE, FIXED
- replaces #70001-00755
70060-04541 $285.16 1 in stock 1 to equal #70001-00755
I just found out this is a 37.5" long shaft so I think it will fit.
The person that sold it to me does not have any driveline parts but I feel im almost done. Thanks a lot for your help and hope this info helps someone else with the same dilemma
I will update this thread when 70060-04541 comes in
Thank you all
/ Front Sweeper B7500 #12
...part DRIVELINE, FIXED - replaces #70001-00755 70060-04541. I just found out this is a 37.5" long shaft so I think it will fit.
spirostats - Glad you got the BX2735! My apologies regarding the information I gave you on the B2734, which is an assembly, however it includes parts that you already have on your Quick hitch. The fixed driveline only is P/N 70060-02186 according to my Operator's Manual. I just measured my fixed driveline and it is 44 3/8" overall length, with about 3" to overlap the mid PTO shaft. Again, sorry about the bad information.
Ok
As per Rusty's latest info I will call messicks this morning and cancel the order I placed last night. I will instead order this Kubota B2733A (QUICK HITCH SUBFRAME) Parts Diagrams. .............DRIVELINE - FIXE- Fixed driveline 70060-02186
As Per rusty this is this is 44 3/8" long and this should be the right length. only thing that worries me is that it states its weight at 6.60 lbs. I would of thought it would be heavier than that...
@ rusty. thats the reason I waited for measurements. Thank you for going to the trouble of measuring I really appreciated it. I previously mistakenly thought that part 02186 was the front half... My mistake not yours.
Thanks man!
Also here is some usefull info from "ducktape" on another thread
As far as the U-joints go..... when you put the frond end shaft on (the one that connects to the blower / sweeper), the yoke on either end of the shaft attached to the quick hitch must be in line with each other. Having the rear yoke at 90 degrees, and the front at 120 degrees will cause a vibration.
/ Front Sweeper B7500 #15
spirostats, I just checked my quick hitch, I misspoke, mine is a B2733 without the A. Dont know what the difference is between the 2 ? Mine LOOKS like yours, but why the part # change ? Will measure my B2734 shaft when I get the chance. Isnt Kubota research FUN ?
Yeah...! loads of fun _:(*&*&^%%*)(()()($%@$%&^$^&
UPDATE
Finally got everything together and it all worked!
I used the sweeper for about 10 minutes, Did a good job but the gearbox broke. This might be my fault, I plowed into a pile of dirt and almost stalled it a couple of times. Or it could have been that it had a problem to begin with. (I bought it used). I will look tomorrow to see if there is a shear bolt or some safety thing or I need to open the gearbox. Bummer!
/ Front Sweeper B7500 #18
spirostats - Congratulations on getting your sweeper running. :) Sorry about the setback. :confused: Hopefully it is temporary with a simple fix. :thumbsup:
Good news. Chain had come off the sprocket. All good. Thanks to all who helped
/ Front Sweeper B7500 #20
I'm looking to sweep my small parking lot and it's good to see this works. Do you have a FEL as well? I have a B7500 with the 272a FEL and also a woods BH75 backhoe with quick attach subframe. Curious to see if this will work with mine and I will start looking for a broom.....Thanks, Chad
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2018 GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
2018 GENERAC...
2008 SHOP MADE (A67714)
2008 SHOP MADE...
2013 STEPHENS CRUDE PUP TRAILER (A67714)
2013 STEPHENS...
Unused 2022 USA Attachments EB-618 18in. Pin On Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2022 USA...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A66734)
2025 Kivel 48in...
