Rustyiron
Super Member
It could also mean the meter has a loose wire.
Or just a loose nut behind the wheel
My apologies to the OP, just couldn't pass that opportunity to use an old joke.
once again, as has been mentioned several times and you haven't responded to, try to source the parts from somewhere else. Again, it is very unlikely that Mahindra designed and built the injector pump and the injectors. Do some research and find out who actually makes them or find an actual Diesel injection shop and have them rebuild the injectors and pump. I doubt that Mahindra will do anything for you simply for still owing money on the tractor. I doubt they will feel any pain if you stop making payments, and obviously that will only hurt YOU in the end.So You just might be right! But as I replied to another person, I owned a Kioti 40 horse diesel that I didn't baby like I baby this Mahindra and ran the "H" out of it for 12 years and since I put revitalazant (see XADO.US) it runs like new. So I used the Kioti to clear our property - never farmed, never cleared desert and drilled over 1,000 post holes and I can easily account for 250+ hours in that venture alone plus all the other use. It had under 160 hours on it. Whilst I thought the hour meter was goofy, I have run my Mahindra several times for just about a week and it has under 60 hours on it. So they both keep time to the same drummer. I use about 5 gallons of diesel a month - some in my Kubota as well.
That said, my comments are simply for one to understand what I did and the consequences thereof. I did everything I said. Those that want to throw stones, please take good aim for they will be returned with good aim. For those who want to help, to understand, to learn, that's my purpose. I did what I said, its my fault if faults your game, its my mistakes and darn, I am going to be paying through the nose for years.
What is disappointing is that Mahindra does have or doesn't have an adequate water extraction process. If its full it should tell you, it should shut the tractor off, because the result is $5,745.10 worth of parts new plus over 2.6 K of labor. I feel that is a deficient design to say the least. Mahindra is ignoring me btw. I have sent them two inquiries. Now I may still get their kind attention because I still owe over one years payments on this ?. For Mahindra to say they are the best selling tractor and design something like this, that seems like fraudulent work to me.
BTW, even when I have it completely running like new, my Kubota dealer told me that they will not take a Mahindra in on trade, period. Aint that wonderful. Bought and live with it for life folks. Yes I made a few mistakes, and I own every last one. Own every last one.
It's actuallybetter for the tractor to run it hard rather than babying it.So You just might be right! But as I replied to another person, I owned a Kioti 40 horse diesel that I didn't baby like I baby this Mahindra and ran the "H" out of it for 12 years and since I put revitalazant (see XADO.US) it runs like new.
Can you show another tractor in that age and size class which has a sensor to tell when there is too much water in the separator and shut the tractor off? I know none of our Kubota's have that.What is disappointing is that Mahindra does have or doesn't have an adequate water extraction process. If its full it should tell you, it should shut the tractor off, because the result is $5,745.10 worth of parts new plus over 2.6 K of labor. I feel that is a deficient design to say the least.
Makes sense, for them to make any money on the trade they would have to lowball you on the trade in and then they would have to support it after selling it.BTW, even when I have it completely running like new, my Kubota dealer told me that they will not take a Mahindra in on trade, period. Aint that wonderful. Bought and live with it for life folks.
Except for checking the water separator weekly as manual recommends?Yes I made a few mistakes, and I own every last one. Own every last one.
Good post Aaron.
Makes sense, for them to make any money on the trade they would have to lowball you on the trade in and then they would have to support it after selling it. As I recall, when we bought a John Deere at work they did take the LS that we had in on trade, but the listed it for sale at about the price that they paid us for the trade-in, so they didn't make much of anything on the trade in.
See above
However, if your sediment bowl is in plain site, as mine is on my Mahindra 2615, it is a simple task to take a quick look and see if things aren't right. In the long run, forget about the factory "suggestions", and seize the day.Here's what the manual says (I just looked it up) ==> "Since water and contaminants settle at the bottom of the sediment bowl, a drain plug is provided at the bottom of the filter. Drain water in fuel, by loosening drain plug once every 50 hrs. of operation." So I was over 40 hours of usage before that needed to be done. The 50 hour service was done at 52 hours at the dealer. Thanks for your kind thoughts.
I check ours every time I fuel up, if not every time I start it up, the bowl is visible from the side of the tractor.However, if your sediment bowl is in plain site, as mine is on my Mahindra 2615, it is a simple task to take a quick look and see if things aren't right. In the long run, forget about the factory "suggestions", and seize the day.
Exactly. It should be checked at every startup in a case like the OP has with such infrequent use.It also helps to understand that when they give service intervals in hours of use it is expected that it will not take half a decade to accumulate a couple weeks worth of run time.
