Quite a shocker let me tell you
   / Quite a shocker let me tell you #51
I thought Arizona didn't have those problems with humidity. Why they park aircraft there for instance.
   / Quite a shocker let me tell you #52
Re: You need to be very careful if you are considering a Mahindra
Have you looked for non oem parts
   / Quite a shocker let me tell you #53
If you decide to keep your tractor, there are additives that deal with algae, water in the fuel, and fuel gelling. I use all three as I may keep fuel for months at a time.
Using all three is a bit expensive, but I am not running 200 hours a year so it is good insurance.
I cannot comment on the possible design faults of your machine, but if you are correct, consider getting it repaired and trading it. If you use it less than 15 hours a year, it may make sense to hire out the work you need done.
   / Quite a shocker let me tell you #54
Be very careful if you are considering a Mahindra
Couple of years ago when I was shopping for a new tractor I did lots of asking around. Lots of reading. One thing I did notice was that a good dealer / repair shop could make or break ones opinion of a brand. Other thing I noticed was a sort of common theme in that IF a Mahindra tractor had serious problems it was not unusual for even a good dealer to have issues with providing repairs and parts.
Was a major part of the reason I did not buy one. Other main reason was a concern with the local dealer.
   / Quite a shocker let me tell you #55
We bought a brand new Kubota hay mower and didn't use it until the warranty had expired. About 15hrs into it's first season it had a catastrophic failure. Kubota ended up taking care of us, but it took a lot of effort on our part to get them to work with us (and they certainly weren't obligated to). Point is, you have a 7 year old machine and I don't believe Mahindra should be expected to help out financially.
   / Quite a shocker let me tell you #56
Re: Be very careful if you are considering a Mahindra
That is just too cool Andy . . . :thumbsup:
That's just the tip of the iceberg compared to some of the things he's posted. It's also a very good idea.
   / Quite a shocker let me tell you #57
I bought a 3510 a few years back. Thought it was going to need a new engine. Not a single one in the USA. Mahindra had one overseas that was 12 weeks out and the cost was more than what I could go buy a whole identical running 3510 tractor for. I luckily ended up not needing a motor and quickly sold it. I have bought my last Mahindra unless its one I get super cheap to flip and resale.
   / Quite a shocker let me tell you #59
if you do repair & keep, am sure you can add an inline water separator, filter set up. highly recommend esp w/your low hr usage. & and yes to above re:additives best of luck
   / Quite a shocker let me tell you #60
Why do you even own a tractor if you dont use it?
Do you use every tool in your tool box more than once per year?Laffin..
6' LANDSCAPE RAKE, 3PT (A52708)
6' LANDSCAPE RAKE...
2009 Honda odyssey (A55788)
2009 Honda odyssey...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2013 Chevrolet...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A56435)
2014 Doyle Dry...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
GRAIN BIN - APPROX. 14' ACROSS (A52708)
GRAIN BIN -...
