Komatsu Dozer wont start
/ Komatsu Dozer wont start #1
KyleB83
Anahuac, TX
John Deere 410C Gehl 303 Mini, Bobcat T650, Kioti CK 35, Komatsu D53-16
We have a D53-16 that cranks but wont start. I am getting diesel all the way up the fuel lines to the injectors. Even trying the gas soaked rag only gets it to run for a few seconds. I am leaning towards clogged injectors.. any tips or tricks to unclog them?
/ Komatsu Dozer wont start #2
Komatsu is a Japanese dozer. You may have better luck in the Komatsu forum.
When is the last time you pop tested the injectors? Are you getting white or grey/white smoke from the exhaust?
/ Komatsu Dozer wont start #3
It doesn’t make much difference. There isn’t much difference between any basis Diesel engine.
/ Komatsu Dozer wont start #4
Are you sure it's diesel and not water getting to the injectors??
That may sound like a stupid question, but I've seen it several times in the past...
SR
/ Komatsu Dozer wont start #5
Disconnect a hard line and remove an injector. Reposition the hard line so you can re-install the injector on the hard line outside the engine. Purge all the air from the hardline and crank the engine and see if the injector sprays. If it sprays, can you vary the ammount with throttle position? Check fuel quality as mentioned.
If it doesn't:
1. There is still air in the hardline.
2. The throttle is not high enough to allow the governor to deliver enough fuel to run.
3. The shutdown lever is not fully released and is preventing the governor from opening the rack.
4. The governor is stuck/jammed or the mainspring is broken and not letting the governor mechanism open the rack.
5. Injector plungers or pump assemblies have issues...
/ Komatsu Dozer wont start #6
Moved the thread to the general parts/repairs forum. Left a re-direct in the Chinese tractor forum that will expire in a month. You'll probably get more looks over here than in that forum. Good luck with your repair and please continue the discussion....
there is white/grey smoke coming out of the stack when trying to start.. I did have some foaming at the injectors when I cracked those hard lines. They deffinately don't give you a ton of room to work in on these things. I need to find my crowsfeet so I can get the other injectors. I need to do some research on the priming pump, or whatever it is called.. I have fuel flowing freely into that, but nothing coming out.. Not sure if it is suction fed when the filter is feeding the injection pump. Tried to fill the fuel filter bowl with diesel, and bled the injection pump.. My father in law told me this morning he thinks it may have algae in it from sitting for 2 years. We just had the starter rebuilt, and have 2 brand new batteries on it, so I don't think its related to slow cranking, but it does sound a lot healthier when I cover the intake with a gas soaked rag. I really think I need to confirm the hard lines are getting fresh fuel, and not old stuff... but even if it was old watery fuel, wouldn't a few times running off the gas rag be enough to clear that out? I need to do some looking at the throttle as well.. it seems like it is stuck about halfway down at the engine, but the throttle lever has full range of motion.
Thanks for getting this to the correct forum and the advice
/ Komatsu Dozer wont start #8
NO, and I DO think it's the fuel that's the problem...
I would take a clean pail, take the line off the injection pump where the fuel enters it, and use air pressure in the fuel tank to push some fuel through, to see what you have.
SR
I tried that in a few places and had nice clean fuel... once before the primer pump, and again after the fuel filter, granted, I filled the filter so I was probably just creating another air pocket up there. I still think I should have fuel flowing through that primer pump when I pressurized the tank, shouldn't I? I can only get to 2 of the injectors at the top, but can get the hard line off all 4 at the injection pump. Had a brain fart yesterday when we were messing with it, and didn't keep bleeding the 2 injectors to clear out the few bubbles they had.
On a 4 cyl, would 2 injectors be enough to keep it running to self prime the other 2, or am I going to have to get another set of Crows feet for the last 2 injectors?
/ Komatsu Dozer wont start #10
Is it cranking fast enough? I’ve had healthy diesel engines frustrate me and not start if the batteries are down a little or there’s a gremlin in the electrical system (bad ground). My dad’s little JD 350 dozer is one of those machines. It’s in great shape mechanically, but will not start if the cranking speed is just a bit slower than normal.
Also, check intake side and air cleaner. I once had a Komatsu D21 that also would not start. Turns out a squirrel had packed the air intake hose with dog food. I was close to pulling the injection pump before I figured it out.
The starter is a fresh rebuild and both batteries are brand new.. I didn稚 even think to take the air cleaner totally apart
/ Komatsu Dozer wont start #12
"Generally" a diesel has to crank at about 350 rpm to start...
If it starts on two, it will clean the air out of the other two...
SR
/ Komatsu Dozer wont start #13
Your father-in-law is probably correct. Sitting for two years with untreated fuel, and most likely uncovered with less than half a tank of fuel, is just begging for diesel bugs (algae, but not algae). People don't realize how corrosive they are. They can completely ruin a set of barrels and plungers, and injectors. In my own experience they pitted the valve seats of the lift pump so bad it would barely pump fuel. Strongly suggest you treat the fuel with a biocide, and read this.
Microbial contamination of diesel fuel - Wikipedia
He put some in about a month ago.. we drained tank twice before we tried to start it
/ Komatsu Dozer wont start #15
Earlier this summer I started a Cummins that sat for 13 years! It rolled over about 3 times and started right up, with the 13 year old fuel. It's still has that 13 year old fuel in it, and it's still starting/running perfectly!
I don't use ANY additive in any of my diesel fuel! I keep the water out of my fuel, and have never had even one problem!
SR
/ Komatsu Dozer wont start #16
You're getting white-ish smoke when cranking, and that is unburned fuel. Strong possibility that you have one or more dribbling injectors. The bad thing about this is that the unburned fuel is washing the liner walls of oil. That's why I asked about the pop testing.
/ Komatsu Dozer wont start #17
SR
Excellent! It's unfortunate that everyone isn't as lucky as you have been.
/ Komatsu Dozer wont start #18
I'm lucky over and over as I use to buy OLD furnace oil out of tanks for cheep when folks would get rid of their fuel oil furnaces, and run it in every diesel I own. Never have I had even one problem... I do admit, 13 years is the oldest fuel that I know of that I have used...
IF I'm so lucky, how come I can't ever get the right LOTTO numbers???
KEEP THE WATER OUT OF YOUR FUEL!! That's the only thing you really need to do!
SR
/ Komatsu Dozer wont start #19
SR
Using old furnace fuel is good for the fuel components, but bad for the environment. Older furnace fuel is not the same as off-road diesel. It likely had a sulfur content of over 2,000 ppm, or if not so old, 500 ppm (LSD). Sulfur is a key lubricating component of diesel fuel. Any fuel you get nowadays is going to be ~15 ppm (ULSD) whether on or off road. And as you suggest, you can't get your fuel clean enough.
/ Komatsu Dozer wont start #20
You forgot about the part......it was good for my pocket book too! 50 cents a gallon!!
Equipment isn't complaining and I'm not complaining....all is good!
SR
1998 Ford L9501 Louisville 101 Truck, VIN # 1FTYN90K4WVA35579 (A61165)
1998 Ford L9501...
2021 Chevrolet Express 2500 Cargo Van (A61568)
2021 Chevrolet...
2006 John Deere 325 Skid Steer (A63116)
2006 John Deere...
UNUSED KJ 45'X25' DBL GARAGE STEEL BARN SHED (A62131)
UNUSED KJ 45'X25'...
2019 Lynco Mini Mover Aircraft Tug Cart (A61567)
2019 Lynco Mini...
20 Yard Roll Off Dumpster (A61166)
20 Yard Roll Off...
