Flail Mower Top link vs flail mower
/ Top link vs flail mower #1
JD2150 and JD2305
I go through a top link each season with my Caroni TM1900 flail mower. I'm running it on an old Ford 4600. I use the slot attachment point rather than the fixed point.
My pastures do have areas where the tractor is going up while the mower is going down and I suspect that is the heart of the problem. Just thought I'd check in and see if that is anything I can do to minimize the damage. If not, well a top link a year isn't a horrible price to pay I just hate sending anything into the waste stream I can avoid sending.
/ Top link vs flail mower #2
With my rotary cutter & quick hitch, the flex link would often pop out of the QH hook. I'd only put it back at the end of the job or if I needed to lift the mower. It ran fine on just the lift arms. Lots of people use chain instead of a toplink.
Both my flails are the same way. You only need the toplink for lifting it off the ground. They'd mow just fine with only the lift arms connected & the roller on the ground.
Sounds great, how does one use a chain rather than a toplink. I was at a party last night and someone mentioned your solution, I was too embarrassed to admit my ignorance. You'd think at my age I'd have worked past that, but apparently no.
/ Top link vs flail mower #4
Just replace the toplink with a chain. Just get a chain as long as your current toplink. Put a pin through the chain where you would the same as a normal toplink.
When you lift a 3pt impliment the toplink is in tension (pulling) not compression (pushing). So it pulls the chain tight when you lift things. When the 3pt is lowered the chain goes slack.
/ Top link vs flail mower #5
Like this:
And from member Gordon Gould one that is easy to change the length:
/ Top link vs flail mower #6
I have run the same set up as Gordon for the last couple of years on my TM1900 and it works great. I also have used a chain for the top link on my 5' and 10' rotary cutters for years without any problems.
/ Top link vs flail mower #7
That simply makes just too much sense - no wonder I have not yet done it. Thanks, guys.
Jim
UNUSED RAYTREE RMBD72S - 72" HYD DRUM MULCHER (A62131)
UNUSED RAYTREE...
2022 Jeep Grand Cherokee 4x4 SUV (A61569)
2022 Jeep Grand...
SAMSUNG ESPOKE REFRIGERATOR/FREEZER (A62131)
SAMSUNG ESPOKE...
UNUSED SDLANCH REMOTE CONTROLLED BULLDOZER (A62130)
UNUSED SDLANCH...
2007 Ford Crown Victoria Passenger Car, VIN # 2FAFP73V67X124782 (A61165)
2007 Ford Crown...
2020 Harley Davidson FLHP Motorcycle (A61569)
2020 Harley...
