Good fixed shade welding helmet
/ Good fixed shade welding helmet #1
Tractorrr
Gold Member
TN
kubota bx 2370-1
Looking for recommendations on a good fixed shade welding helmet that you can easily flip down. Thank you for your suggestions.
/ Good fixed shade welding helmet #2
A Jackson helmet will be a lifetime item. The large window (4.5 x 5.25) ones run about $50. The flip force is adjustable.
The normal shade is 10. If you are learning and having trouble seeing try a 9. The other truck when learning is to weld with bright lights or sunshine on the work/weld site. You should be able to barely see what you are doing without striking an arc.
If you have the small lens helmet you can also get an ArcOne auto darkening lens as a replacement. These are nice lenses a lot of pipeline welders use with their pancake shields. No frills but they have a great reputation!
ArcOne T240-10 Tradesman Horizontal Auto-Darkening Filter for Welding Helmets, 2 x 4.25 x 0.2" https://www.amazon.com/dp/B003WE9XXQ/ref=cm_sw_r_cp_api_i_U88-CbYYE8DJ8
/ Good fixed shade welding helmet #5
Fibre Metal 190 or 990. Jackson Shadow.
JCT Skid Steer Snow Pusher (A64047)
JCT Skid Steer...
2015 FREIGHTLINER CASCADIA T/A 6X4 SLEEPER TRACTOR TRUCK (A59910)
2015 FREIGHTLINER...
Case TV380 (A62177)
Case TV380 (A62177)
2025 Greatbear Rachet Tie Down & Flatpack Tool Box (A61567)
2025 Greatbear...
HYDRAULIC BOBCAT UTV SNOW BLADE ATTACHMENT (A63569)
HYDRAULIC BOBCAT...
3PT 10' Rolling Cultivator (A60462)
3PT 10' Rolling...
