Old Tractor Seat Barstools
/ Old Tractor Seat Barstools #1
ryan172001
1930 John Deer Standard
I am currently undertaking a project to construct 4 barstools all centred around old tractor seats. So far I have this first current design which involves the use of welded up lengths of chain, this is because I have a lot of this old chain and intend to use it on this project. The base is going to be made of laminated wood and a steel plate will attach to this to then support the welded chain. The sizes on this sketchup design are all made to suit the table that they will be sat around.
However I am seeking some further advise from anyone who can help with information around a more suitable swivel devise which I want to be in place aswell as any other advice around strength, stability, ergonomics different design ideas that could look good aswell as any general advice or ideas.
ANY ADVICE IS APPRECIATED
/ Old Tractor Seat Barstools #2
Just a thought for the base, would a large 20-22" used disc work and look good ? B
/ Old Tractor Seat Barstools #3
There websites like youtube offer good ideas.
/ Old Tractor Seat Barstools #4
I saw one somewhere with a car spring for the pestal.
/ Old Tractor Seat Barstools #5
If you click this image search link you will see many different design ideas: Old Tractor Seat Barstools at DuckDuckGo
/ Old Tractor Seat Barstools #7
The bottom looks a little "clunky" to me. Could you do a tri-pod for the legs with the chains and have the bottom link of each chain flat for support? Then in the middle you could weld a chain flat across for a foot support. You are obviously better at cad than me you could draw up a quick sketch and see if that would work visually.
Curt
/ Old Tractor Seat Barstools #8
I enjoy this kind of art also. This table is in the making. Pintrest is a good source for ideas.
/ Old Tractor Seat Barstools #10
Gives it good ballast, you wouldn't want it falling over and spilling your coffee.
1998 VOLVO AUTOCAR WATER WELL DRILL RIG (A65643)
1998 VOLVO AUTOCAR...
3'x8' Stack of Sheet Metal (A64127)
3'x8' Stack of...
New/Unused 7ft Double Chain Sling (A65583)
New/Unused 7ft...
2012 CATERPILLAR D8T HIGH TRACK CRAWLER DOZER (A65053)
2012 CATERPILLAR...
More info coming soon (A61569)
More info coming...
2023 John Deere Z994R (A64127)
2023 John Deere...
