Brush mower swing arm
/ Brush mower swing arm #1
woody
Central Alabama
Kubota B26, Kubota ZG222, Kubota L45, 1980 Ford 1700
I have a chance of getting a swing arm brush mower, do you TBN experts think my L45 can handle the side weight of the mower?
/ Brush mower swing arm #2
It looks to be hydraulic driven. If so check your hydraulic flow capacity to verify it is adequate.
/ Brush mower swing arm #3
^x2
Also, do you know the weight of the entire apparatus? Along with the entire length?
From there, with some simple maths, you can then calculate the loading factors.
/ Brush mower swing arm #4
Man, that would be some serious weight hanging off to one side of your loader.
Swing Arm Boom Mower Skid Steer Loader Attachment
Skid Steer
Requirements
17-30gpm
The swing boom cutter should only be
used on 70+ HP skid steers with a lift
capacity of at least 1800 lbs. and with a
weight of at least 6500# with the
bucket removed. A skid steer equipped
with tracks will provide superior
stability in this application.
Weight: 1025lbs.
CID Swing Boom Brush Cutter Driveway Maintenance Demo Video - YouTube
/ Brush mower swing arm #5
The L45 has the TLB loader, which is the TL1000A. Max lift capacity is ~2,800 lbs. I doubt that mower weights more than 1,000 lbs. Wish the picture was clearer.
/ Brush mower swing arm #6
You are probably borderline being able to lift that with your loader, but there will be a lot of extra wear and twisting to your loader if you used it very often. The bigger question is if you have enough hydraulic pressure to run it? and if you do, how much more cooling will it require to deal with the increase maxing out your hydraulic pump?
/ Brush mower swing arm #7
I’d be worried about the side load. A skid steer is a lot more capable of taking that force.
Skid Steer
Requirements
17-30gpm
Weight: 1025lbs.
Thanks guys Ruffdog nailed it. all good advice the only thing is the 70+ horse power and the 17-30 GPM. I think the GPM would be alright and I was not planning on using it very often but I don't want to tear something up trying to make things easier on myself.
/ Brush mower swing arm #9
The 10gpm at 2,500psi on the Grand Ls is only 15hp at best. I bet the TBLs have a little better flow, but not by much. You'll end up with less power than a riding mower trying to spin that beast. Not to mention the ballast issues previously mentioned.
That's what I was worrying about I think the L45 is about 12GPM
2023 Kubota L6060HST Compact Utility Tractor (A63118)
2023 Kubota...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A61567)
2002 Bobcat 863...
John Deere Gator TX4x2 (A62177)
John Deere Gator...
CAR LIFT (A62131)
CAR LIFT (A62131)
2013 International WorkStar 7400 Altec Bucket Truck (A61568)
2013 International...
2012 INTERNATIONAL 4300 4X2 26FT NON CDL BOX TRUCK (A59908)
2012 INTERNATIONAL...
