Post hole digger adapter pin
/ Post hole digger adapter pin #1
ning
Elite Member
Northern California
Branson 3520h
My phd has an adapter sleeve which fits the augers that I have (2" round). Recently I lost the sleeve, until I found it down inside the center of the auger...
I believe the sleeve is held on by a spring pin. I found something like one by the auger, but it's not obviously springy and also was pretty short - should this be a spring pin?
/ Post hole digger adapter pin #2
Not sure what I am looking at from your photo (too close up) but if that is the sleeve where the auger attaches to the PHD gear box, then it just requires a shear bolt to connect it. Make sure it is a tight fit (correct bolt size). Not sure what the little sleeve that you are holding goes to.
Turns out the parts guide is wrong; it needed a 5/16" roll pin, 3/4" long. All set now.
Many thanks - this is a 500 unit and that's supposed to be #12 - Roll pin 1/4" x 2", though I only have 1/2 left apparently
TEST YOUR BID BUTTON! (A63290)
TEST YOUR BID...
2020 Peterbilt 348 Vermeer Mega Vac VXT8 Tri Axle Vacuum Excavator Truck (A60352)
2020 Peterbilt 348...
TARP ON PALLET (A63745)
TARP ON PALLET...
2014 Lamar Pipe Trailer (A60460)
2014 Lamar Pipe...
FORREST CITY 2R48" RIPPER BEDDER (A63290)
FORREST CITY 2R48"...
Knapheide Service Body w/ Ladder Rack (A62613)
Knapheide Service...
