Post hole digger adapter pin
/ Post hole digger adapter pin #1
ning
Elite Member
Northern California
Branson 3520h
My phd has an adapter sleeve which fits the augers that I have (2" round). Recently I lost the sleeve, until I found it down inside the center of the auger...
I believe the sleeve is held on by a spring pin. I found something like one by the auger, but it's not obviously springy and also was pretty short - should this be a spring pin?
/ Post hole digger adapter pin #2
Not sure what I am looking at from your photo (too close up) but if that is the sleeve where the auger attaches to the PHD gear box, then it just requires a shear bolt to connect it. Make sure it is a tight fit (correct bolt size). Not sure what the little sleeve that you are holding goes to.
Turns out the parts guide is wrong; it needed a 5/16" roll pin, 3/4" long. All set now.
Many thanks - this is a 500 unit and that's supposed to be #12 - Roll pin 1/4" x 2", though I only have 1/2 left apparently
2018 Chevrolet Express Van, VIN # 1GAWGEFGXJ1184696 (A61165)
2018 Chevrolet...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
43023 (A59228)
43023 (A59228)
2023 CATERPILLAR 259D3 SKID STEER (A62129)
2023 CATERPILLAR...
2017 Ford F-250 Service Truck (A61568)
2017 Ford F-250...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
