Loader Brand new BX2380 Front End Loader Issue/Damage
/ Brand new BX2380 Front End Loader Issue/Damage #82
Okay, you're probably all still anticipating the outcome. ... I do appreciate all of the genuine helpful suggestions here, and I apologize for my lack of participation, but I was pretty ticked off for a while and needed some time in denial.
You changed your handle from Mummer and started a new account I guess? After all the dust settled was there any actual damage or is everything good ?
/ Brand new BX2380 Front End Loader Issue/Damage #83
I'm not Mummer. I just piggybacked on this thread instead of starting a new one, since I had the same thing happen. I think he had real damage to his tractor. My only damage was that the hooks that hold the loader stand up while installed got bent; the tractor has a few scratches on the grill guard. A few hits with a rubber mallet made the hooks functional.
/ Brand new BX2380 Front End Loader Issue/Damage #84
OMG, just discovered this old Post and the OP has me laughing my *** off. I looked at his pictures and Holly Crap, he really screwed the pooch...
/ Brand new BX2380 Front End Loader Issue/Damage #85
Not really a laughing matter at all IMO.
/ Brand new BX2380 Front End Loader Issue/Damage #86
I would like to how the OP ended up.
/ Brand new BX2380 Front End Loader Issue/Damage #89
I'm sure this kind of thing happens more than you think. They're just to embarrassed to post.
/ Brand new BX2380 Front End Loader Issue/Damage #90
I actually responded last year on this post, but clearly, missed the photos. All I can say is... if you back into the garage door with your car, you don’t floor it and drive out the back wall. Holy cow! I can’t see the dealer OR Kubota accepting the damage as a warranty item. Too much damage was created by what looks like a ticked off operator. After it was noticed the loader was not correct, he should have stopped. I move my loader (BX267O) around by hand without a dolly all the time. It’s not that heavy. It’s pretty obvious from experience that one side was not locked in the mount saddle, and the OP retracted the lift cylinders, pulling the arm out of the saddle further. Once the arms are out of sequence (different positions), the lift cylinders need to be manually equalized to set them in the same position. The OP just kept fidgeting with it and destroyed the loader and tractor.
/ Brand new BX2380 Front End Loader Issue/Damage #91
"It’s pretty obvious from experience"
Or lack thereof...
This is where the problems start. Lots of guys getting off a 38" craftsman and getting on something they are not familiar at all. Hard to believe there's not more people getting hurt.
/ Brand new BX2380 Front End Loader Issue/Damage #92
Or lack thereof...
You got that right!
/ Brand new BX2380 Front End Loader Issue/Damage #93
You mean I read this entire thread not realizing it was two years old without the OP telling us the resolution???
Shame on me I guess...
Think the site needs a middle finger emoji for the OP!
Usually not this crude...:mad:
/ Brand new BX2380 Front End Loader Issue/Damage #94
This one work ?
/ Brand new BX2380 Front End Loader Issue/Damage #95
Dude got what ferred from Professor Orange early on as many others have. No surprise he seagulled. Probably figured he wouldn't get a lot of help, so there was no reason to endure more finger pointing.
/ Brand new BX2380 Front End Loader Issue/Damage #96
Actually, at 1st, he was getting help, he was getting good advice. He just chose not to listen to it, and kept trying to fix it himself. I think he even said, "what more harm can i do" or something to that effect.
I'm thinking he had to eat a lot if not all the repair bill, and is to embarrassed to come back and admit it.
/ Brand new BX2380 Front End Loader Issue/Damage #97
After five years of install/remove the FEL, I screwed up bad. IIRC It was late and I was tired and forgot to put the stands down. Ended up denting the grill, scratching the side panels and damaging some hydraulic lines. IIRC I had to take the FEL apart to get the cylinders aligned.......IIRC.
Cheers,
Mike
/ Brand new BX2380 Front End Loader Issue/Damage #98
Maybe you wise guys can offer up a SCUT 101 class made available to all new owners as part of the purchase? Give the guy a break... like you all have not screwed up anything before.... right?
/ Brand new BX2380 Front End Loader Issue/Damage #99
I think he's back guys, LMFAO!!
2007 Ford F750 Dump (A62613)
2007 Ford F750...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A61307)
Neckover GL24-2-7K...
2016 CATERPILLAR 416F2 BACKHOE (A62129)
2016 CATERPILLAR...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2011 Ford F-750 Terex Hi-Ranger 5TC-55 55ft. Insulated Bucket Truck (A60352)
2011 Ford F-750...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
