Trailer questions
/ Trailer questions #61
I agree on using the wrong tool for the job. That trailer is made for a much shorter load and has the axels too far forward. And your truck isn’t rated for anything close to 6,000 without brakes and no weight distribution hitch. That load probably weighs more than 6,000 anyway. Do the smart thing and park that rig before something bad happens.
/ Trailer questions #62
I have to agree... this is a kind of a stumbling thing in every which direction. The little short trailer may not be a POS as FTG said but at best it is the WRONG TOOL for what you are trying to do. You said in the other thread regarding the "ethics" of your dealer where you bought the Kubota and backhoe that the dealer was close by, yet you had no way to haul it to him. Thankfully the dealer now says he'll come to you and make it right. GOOD (in the other thread but very related to this one.)
1) The trailer might even be solid with need of some maintenance but it looks like just a misfit. The axles are in the middle because it was made very short for specific kind of loads and there is not much of it except FOR the middle ! You bought a rather specialized skid-steer or small excavator trailer and are trying to make a more gen purpose one out of it (or get-by as-is.)
2) You do not sound like you have any intent to use the brakes on the trailer. You need the brakes with that "heavy hauling Ranger" truck especially, [so aptly named by 4570!] and should have them regardless. I don't want to be on the highway where ever you are.
3) You never did say why you must pull with the Ranger, having also said you have larger trucks around like Dodge pickups AND that your intent is not very frequent hauling. This just isn't a logical scenario...
4) I don't know how great a deal you got on the WRONG TOOL but you need to re-sell it and go get the right tool for what you want to do. Us peanut gallery people on TBN can offer 40 or 50 pages more advice but you really ought to sidle up to a a friend or knowledgeable equipment person you see often and get on-site guidance on your soon-to-be purchase of the RIGHT TOOL.
Who knows, if you got a great deal on the trailer we've been discussing, you might make a little cash on it while you go find a better fit for your tasks.
I was just about to post something to this effect, but couldn't have said it this well, so I'll just +100 and amen to it all - especially about not wanting to share the road with you.
Z.
/ Trailer questions #63
Z.
Not to pile on, but I agree as well. I towed 6.5k behind my Tacoma with better ballance & good brakes a couple times. I was within the ratings for the truck, but it was not comfortable. I promptly got a better truck for future towing.
Its illegal to run a trailer over 3k lbs without properly functioning brakes in most states for very valid reasons. The moral, not to mention legal implications of endangering others with improper gear or at least improperly setup gear is not good.
/ Trailer questions
My heavier trucks are at home with me, the property where I am working is 2 hrs away, I keep the ranger in the same storage container as the tractors, I drive the Ranger maybe 20 miles in 2-3 months, the trailer is used much less, it sits outside my storage container.
I gave 300 dollars for the trailer if i remember correctly, I gave more initially but called the knot head on the way home, told him I knew he sold me a lemon ( cause of the swaying ) and he quickly reimbursed me several hundred dollars on my paypal cause I made it clear I wasnt gonna just walk away.
I pulled my little Kubota this A.M to the shop, it was loaded as far forward as I could get it, no swaying whatsoever, Im gonna cut the ramps off, take it for a ride, see what happens, if all is good than I will fabricate a new way of attaching ramps so they sit flat on trailer, if the ramps arent the issue than I will get rid of the trailer and start over.
I need a trailer on my property to haul my tractors to the dealer if need be, really no other reason, I have a 20 ft dual axle car hauler at my home that I use often for everything else.
I have no interest in hurting anyone because I was only considering myself
/ Trailer questions #65
Also (IMO), its one thing to be over that weight with a bigger truck (such as a 1 ton towing 4000# with no trailer brakes but good weight distribution), its another to be using a truck (such as this ranger) at the limit of its tow rating with a no trailer brakes and poor weight distribution...
Aaron Z
/ Trailer questions #66
Please, do yourself and those on (or near) the road with you a favor and fix the trailer brakes and put a brake controller in your Ranger ASAP.
Even if its just a cheap timed brake controller (available for $25 in Amazon: https://www.amazon.com/Reese-Towpower-74642-Brakeman-Compact/dp/B0016KA9PY/ ), it makes all the difference in the world to be able to hit the button to turn on the trailer brakes and have it pull back on the truck to reduce its sway...
Aaron Z
/ Trailer questions
Aaron Z
I know nothing about any of this but I WILL you tube it. Thanks
/ Trailer questions
If you dont mind...how do they work, I think Ive seen a hydraulic brake line on my trailer ( one single line coming up to the tongue ) but you make it sound like its electric?
/ Trailer questions #69
If the 20ft trailer is a flat deck trailer l would use it to haul the bigger tractor on. I completely understand the need for 2 trailers because when ones at home and you are at the other place, it never fails that you should have brought it with you. The smaller trailer might be a good match for the smaller tractor. I have a friend that has the smaller wheels on his car hauler trailer because he is alway getting old cars and truck to paint or fix up and it was specially made for the low clearance to get non running vehicles on. I would definitely tow with the larger trucks and use the ranger to run back and forth in.
/ Trailer questions
It is a flat deck car hauler. Thanks
/ Trailer questions #71
There are 2 main types of trailer brakes for non CDL trailers. Electric drum brakes & hydraulic surge brakes.
Electric are the most common. The controller in the tow vehicle sends varying levels of power back to magnets in the brakes. Those magnets engage the brake shoes. The more voltage the harder the braking.
The other type, popular with boat trailers & rental yards are hydraulic surge. They operate just like brakes in your car. Push in brake pedal, which pushes on the master cylinder, which pushes on the slave cylinders squeezing the brakes. Only the master cylinder is in the tongue of the trailer. When the vehicle slows down, the trailer tries to ram into the hitch & compresses the master cylinder.
You can easily test a brake controller by hitting the override lever & letting the trailer brakes slow the vehicle. Really you should be doing that every time you hitch up to validate things & recalibrate power levels every time the load changes. It's a bit harder to validate surge brakes are working correctly. They need periodic maintnance too or they freeze up & dont work.
Manually engaging electric brakes also stops sway in emergencies. Stomping on vehicle brakes makes sway worse. I have a big preference for electric brakes for this among other reasons.
/ Trailer questions #72
Well said, and I can't argue with any of it. But... since most of my 40+ years of towing has involved boat trailers and salt water, I won't suffer drum brakes of any kind. Typical scenario: shoes wear into drums, adjusters rust solid, can't back off the adjusters to get the drums off. Lots of bloodshed and navy language ensues...
Both of my trailers: the one I haul my 6000# boat on, and the one for my little kubotas, have quad disc surge brakes. Easy to maintain, easy to flush off, and highly effective. By skill with tongue weights (make that dumb luck...) I've never had a sway issue <knock on wood> so I'm a disc/surge fan and wouldn't have anything else.
Z
/ Trailer questions
I'm sorry that I didn't get pictures but just to update, I removed the steel ramp plate and that made a world of difference, I went from going very slow to about 55ish before it started feeling squirrely.
I then thought that if I leaned the ramps back a bit they would catch less wind.
Nope, only made things worse by adding weight even further out.
Looked at axles and they are bowed like a smiley face so I'm assuming not bent
I put my B6100 on it all the way forward, 65-70 down the highway with no issues whatsoever.
It's truly all about the weight placement and the ranger being a small truck.
I don't think there is anything wrong with trailer, drove my small Kubota and a full loaded truck 130 miles Fri evening and no issues
Kubota dealer finally came out to my property yesterday a.m, showed me how to remove my implements.
Trailer is now sitting on my property and may not be used again for months but when I do need it I'm sure it will be ok, with the backhoe/front end loader removed.
/ Trailer questions #74
"I have no interest in hurting anyone"
But,.... you WILL hurt someone pulling THAT trailer, with no brakes, and that little Ranger.
I was the VICTIM of an improperly rigged trailer.
Loose trailer on I-95...... at 75MPH.
High speed crash!
Please get that cheap POS killer off the road, and please do NOT sell it to someone else!
Do the RESPONSIBLE thing, and eat the net $100 you paid for the trailer.
/ Trailer questions #75
You do not even know what electric brakes are, but you have a "car trailer at home"?
The car trailer has surge brakes?
No brakes at all either?
If you hurt me or my family, you will pay me for the rest of your life.
I believe the attorneys call it..... "willful negligence".
/ Trailer questions #76
You assumed incorrectly. They should be like a frowny face so that as you put weight on a trailer, they flatten out. If they are bowed like a smiley face, that means that they will chew up the inside of the tires and it will get worse as you put more weight on it.
No issues other than a complete and total lack of brakes on the trailer in case something goes wrong or somebody does something foolish in front of you?
That and luck in your case.
Aaron Z
/ Trailer questions #78
With that combination of willful ignorance and attitude, please don't leave FL.
/ Trailer questions #79
An axle bent like a smile face is a severely destroyed axle. Your axle should be crowned up in the center of the tube and the tires should be leaning out at the top while it is sitting empty as you apply load to the trailer the top of the tires will come back into vertical and the center of the axle tubing itself will deflect downward in the center slightly.
But just as an empty tractor trailer going down the road looks like an arced up bridge in the center of the long flatbed trailer, your axle should be arced up into the center also.
2007 FRAC TANK 500BBL WHEELED (A60736)
2007 FRAC TANK...
iDrive TDS-2010H...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
SKID STEER ATTACHMENT TILLER (A58214)
SKID STEER...
New/Unused Two Wheeled Electric Bike (A61166)
New/Unused Two...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
