Barn vertical steel siding fastener pattern
/ Barn vertical steel siding fastener pattern #1
Tompet
Ohio
Ferguson TO 20, Kubota B3300, BH77, Massey Ferguson 1540
Anyone with experience on vertical steel siding pros and cons of fastener pattern choices of attached file?
/ Barn vertical steel siding fastener pattern #2
I personally would probably do the second at the top and bottom and the first for the mid-panel sections.
/ Barn vertical steel siding fastener pattern #3
I’ve never seen a #2 pattern. I assume it would be an engineer spec for more sheer or wind resistance.
/ Barn vertical steel siding fastener pattern #4
The way I read that sheet, you use both. Pattern 1 for intermediate areas and pattern 2 for base, eave and sheet ends.
/ Barn vertical steel siding fastener pattern #5
I have always used the 1st pattern except for the stitch fastener with no problem in KY. If it is a very, very windy location the stitch may be of use.
Yes, I see that point, but as pburchett said using pattern one would work and as to pattern three leads me to the question of going through each raised rib vs each side of rib?
And then on each it gives a fastener sequence that seems a bit odd...?
Thanks for the feedback!
/ Barn vertical steel siding fastener pattern #7
Usually you screw on each side of rib at ends of metal. Is this for walls or roof? Walls I wouldn't worry about screwing the rib on the lap.
Yes only walls. Roof is Meridian 16” which was least expensive snap with clips standing seam roof.
/ Barn vertical steel siding fastener pattern #9
Pattern 3 is for attaching trim. You have to go through the rib. It's the only place it makes contact with the trim.
/ Barn vertical steel siding fastener pattern #10
I’ve always done it as shown in the top example, but I put screws on both sides of the rib where sheets overlap.
/ Barn vertical steel siding fastener pattern #11
I have seen all types with all kinds of different reasons why.
I have built 3 different pole barns of different sizes. I always screwed the metal on the same way and have never had a problem. This was in a high wind area also.
Here is how I did mine.
2010 GREAT DANE SUP-1114-11053 53X102 REFRIGERATED TRAILER (A59914)
2010 GREAT DANE...
Kuhn FC 4000 (A64126)
NEW ATA-EPC40 Plasma Cutter (A62679)
NEW ATA-EPC40...
2003 International 4300 Bucket Truck (A62613)
2003 International...
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
2016 Volvo Semi Truck (A66285)
2016 Volvo Semi...
