LA304 Loader on a B7100
/ LA304 Loader on a B7100 #1
Newbie7100HST
Member
Ottawa, ON
Kubota B7100D HST, Belarus 255
Hi.
Has anyone ever shoehorned a LA304 loader onto a B7100HST?
I picked the loader up yesterday - too good of a deal to pass up even it if I can not make it fit.
I have to fabricate a subframe for the tractor to mount the quick attach arms to, but a quick look at the boom arms tells me they are not wide enough to clear the big stock air filter breather. I was thinking about taking the big breather off and installing a KandN style foam filter like I use on my snowmobile.
I do not know too much about the fuel/intake systems on these engines - does anyone think using that type of filter could lean the mixture out too much and cook my engine?
Thanks.
/ LA304 Loader on a B7100 #2
Try turning the breather to be facing back and adding longer 90 deg. rubber hose as far back as needed. You well have to make a bracket to hold it.
/ LA304 Loader on a B7100 #3
Hi.
Thanks.
it's Not possible to lean out the air fuel mixture on that diesel... it Always operates with all the air available and only varies the amount of fuel... I would not use a K&N type of filter, not an adequate filter for a diesel engine.
Ok. Thanks for the info regarding the fuel/air.
With regard to the filter, I知 guessing your concern is that the foam doesn稚 have a small enough micron measurement, rather than the physical shap/size of the filter. If I found a sommelier size pleated paper/fiber filter I wouldn?t foresee an issue?
Thanks
UNUSED ATS EPC40 ELEC.PLASMA CUTTER (A62131)
UNUSED ATS EPC40...
UNUSED KJ 14' EXPANDABLE SITE FENCE (A62131)
UNUSED KJ 14'...
New/Unused Landhonor Quick Attach Pallet Forks (A61166)
New/Unused...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
BUSHHOG 2615 LEGEND BATWING MOWER (A63276)
BUSHHOG 2615...
2015 TAKEUCHI TB240 EXCAVATOR (A62129)
2015 TAKEUCHI...
