Wheel Spacer Question: 1" vs 3"
/ Wheel Spacer Question: 1" vs 3" #1
Henro
Super Member
Few miles north of Pgh, PA
Kubota B2910, BX2200, KX41-2V mini EX
Hi,
I am about ready to order wheel spacers for my Kubota B2910.
I have settled on 3" spacers, but only really need 1" spacers for chain clearance.
So my question is: Is the 2" difference between 1" and 3" spacers significant? I know wider is better. But "how much better" is what I am wondering.
Perhaps not a question with quantifiable answer...I do know the wider track would FEEL more stable...
...Just like my van runs better after I change the oil. :laughing:
Thoughts/opinions appreciated!
/ Wheel Spacer Question: 1" vs 3" #2
Hi,
Henro . . . do you actually need the wider track? The further you push your tires out the more strain on your B2910 axles.
/ Wheel Spacer Question: 1" vs 3" #3
Calculating tire chain clearances to a 1 inch tolerance sounds like a recipe for wadded up fenders. Get the 3 inch spacers.
Do not know if I need more than 1 inch. But once in 15 years I did end up with the tractor on its side. So extra stability can not hurt. Just not sure how much difference a couple inches on each side makes.
/ Wheel Spacer Question: 1" vs 3" #5
I doubt you'll tell the difference in stability with the 1" spacer. I've added 2"ers to my L3400, and really isn't noticeable. Go with the 3".
/ Wheel Spacer Question: 1" vs 3" #6
We added 4" spacers on each rear wheel of our L3800. It make a very noticeable, very positive difference in stability.
/ Wheel Spacer Question: 1" vs 3" #7
2” rear wheel spacers and ballast in tires made a comfortable difference with mowing hilly ground with B26. Less tippy with backhoe. Also helps with grapple stability. Front tires have Gemplers bulletproof flatproof liquid. HD loader is hard on front tires if they are the least bit low.
/ Wheel Spacer Question: 1" vs 3" #8
:) . . . push those babies out then. ;)
/ Wheel Spacer Question: 1" vs 3" #9
Hi,
I'm of the wider is better school of thought. Actually in my case, wider is a necessity since a lot of my property is literally the side of a mountain. That is a 6 foot hog.
Hi,
After thinking more about this I may spend the extra $ and go with 4 inch spacers.
Decided that 3 inch will be the minimum as stability increase is more important to me than chain clearance, and satisfactory chain clearance comes with any spacer I buy.
Initial motivation for purchase is chain clearance, but the real reward for spending the money is increased stability.
Did not order yet though...but will soon.
/ Wheel Spacer Question: 1" vs 3" #11
If the question is between 1" and 3" then why not go with 2"?
I highly recommend Bro-Tek for wheel spacers. Richard gives top notch customer service and very reasonably priced. If your specific model isn't listed on his website then send him an email through the site. He will be able to make them. I was very pleased with the 2" spacers he made for my Mahindra.
/ Wheel Spacer Question: 1" vs 3" #12
Hi,
You absolutely will not regret 4" spacers per side. I was hashing it over as you and went with 2 two inchers per side and increases the stability mucho.
/ Wheel Spacer Question: 1" vs 3" #13
Hi,
I would not go with 1" spacers on a tractor unless they are a "true" spacer, fitting on longer lugs that then secure them and the wheel to the hub together. - - Std spacer design has a double hole pattern with big counterbored holes allowing use of the original lugs to hold the spacer to the hub, and then threaded holes offset 1/2 space for attaching the wheel to the spacer. In this configuration a 1" [aluminum] spacer would be pretty flimsy.
In the latter design configuration for tractor use I would go to 2" minimum.​
2016 JCB 3CX 4x4 Loader Backhoe (A64194)
2016 JCB 3CX 4x4...
2006 Volvo Semi (A64047)
2006 Volvo Semi...
1996 MACK MIXER (A63569)
1996 MACK MIXER...
2009 JACK COUNTY KILL TRAILER (A58214)
2009 JACK COUNTY...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
2015 Ford C-Max Hatchback (A61574)
2015 Ford C-Max...
