Yard Prepped and Seeded - Just Before the Rain
/ Yard Prepped and Seeded - Just Before the Rain #1
LukeDuke30
Indiana
2016 Massey 1734e
I had several posts about the best methods for yard prep before seeding, seeding, and then to cover or not to cover. In any case I picked up a used 6' Land Pride Pulverizer. Back history, we built two homes on an 11 acre lot this past year. My in-laws live on one side and are there part time between here and California. So, in early April I was able to get some practice in on their yard using the same method. Their grass came up nicely in about 2-3 weeks. It was very rainy and cool, so it took a little longer.
It has been so wet this spring that I have not been able to get mine done. Yesterday, it was just dry enough. I spent about an hour going over it to get the level, powdery, but firm consistency needed for a seed bed. I fertilized it with a starter fertilizer, and hit it heavy with a Kentucky 31 Fescue/Bluegrass mix. I then went over the entire area again with the pulverizer which covered the seed, and also packed it again. Pics below. It rained about an hour after I finished. It rained fairly heavy, but there was no washout this morning, and the seed was still just under the surface where I left it. Looking forward to the results. Forecast is cool and fairly rainy for the next week.
/ Yard Prepped and Seeded - Just Before the Rain #2
Sweet tractor work...keep us posted! I'll be doing this in less than a year myself, so I'm subbed.
TXCOMT
/ Yard Prepped and Seeded - Just Before the Rain #3
Looks good except I don't like seed blend
Bluegrass is fine blade, but ky 31 is course blade grass
I should have specified - I had a few lbs of leftover bluegrass mix. It is probably less than 10% of what I actually put down. It was about a year old, so I mixed it in.
/ Yard Prepped and Seeded - Just Before the Rain #5
Nice job.
I always roll my seed. To me, it's just the finishing touch. Also seems to promote faster germination with better soil to seed contact.
Last years project.
Grass came up nice after a bunch of watering.
Now it looks, so-so, as a lot of that grass mix used for quick cover dies over the winter.
Looks great! My pulverizer has a roller on the back with spikes. It is heavy enough that it packs the soil down well.
/ Yard Prepped and Seeded - Just Before the Rain #7
I don't know what a pulverizer is. Do you have any pics?
I've decided to wait until Fall to seed my new build area. I wasn't ready early enough. Afraid if we get another mid Summer drought it would all die.
/ Yard Prepped and Seeded - Just Before the Rain #8
Nice work! There seems to be a very small window here where things dry up enough to get seed in, but still leave you with enough rain to get the grass started.
/ Yard Prepped and Seeded - Just Before the Rain #9
Here it's possible to seed in the Spring or Fall. If seeded in Spring you need consistent rainfall all Summer. That's iffy. You got about 60% chance of success if you can't irrigate with a sprinkler. Fall seeding almost always works. Only failing if applied wrong, buried too deep, etc.
/ Yard Prepped and Seeded - Just Before the Rain #10
You might want to go over it with a roller. Those little grooves don't look deep now but wait till you start mowing. It will ride like a washboard. I went over some of my land with a landscape rake and it looked very similar. I have to mow with the grooves or it beats me to death.
/ Yard Prepped and Seeded - Just Before the Rain #11
And the wrong rain will bury the seeds in the valleys, leaving strips of grass growing. That takes a couple years to go away.
/ Yard Prepped and Seeded - Just Before the Rain #12
Agreed, I finished my yard with a spike harrow and it took many years for mother nature to smooth it out.
/ Yard Prepped and Seeded - Just Before the Rain #13
I suppose it depends on the soil, but I had a different experience. While I agree that flatter and rolled is always better, I have prepped areas that looked like the OP's at the end of my prepping. One year later flat as a pancake and all areas filled in with grass.
As always, one can't let perfect be the enemy of good enough.
After the rain we just received on Friday, and again on Sunday the lines you saw in my pictures have vanished for the most part. With temps in the high 70's and low 80's this week with rain every other day, I am hoping to get some germination soon.
Looks just like this but a 72''
/ Yard Prepped and Seeded - Just Before the Rain #17
I've never saw one being used or in person. But now I remember having saw a pic of one like the one you posted.
Does the soil need to be pretty dry??
/ Yard Prepped and Seeded - Just Before the Rain #18
Good luck with Kentucky 31. I cheaped out and seeded about 1/4 acre with it years ago. Every year I threaten to kill it and seed it like the rest of the yard with a bluegrass/red fescue mix. Just don't like the thick fast growing blades that need mowed every 3 days. Rest of yard is perfect. I think it belongs in a pasture.
2018 Hino 195 20ft. Box Truck w/ Electric Liftgate (A64556)
2018 Hino 195...
44in Single Cylinder Grapple Bucket Skid Steer Attachment (A64553)
44in Single...
2022 EZ-GO ELITE...
New/Unused CFG Industrial H15R Mini Excavator (A65579)
New/Unused CFG...
2005 CATERPILLAR 416D BACKHOE (A65053)
2005 CATERPILLAR...
Jack Daniels Sign (A64557)
Jack Daniels Sign...
