Rounded off drain plug
/ Rounded off drain plug #1,681
Looks like there may be enough room in the pan boss to just drill and tap a new hole...
But I would probably first try welding a wrench onto the stub that's left. Worst that can happen is that you twist it off.
Then you have two choices:
A) drill out the existing plug and hope you get your drill centered (and parallel).
B) drill and tap a new hole.
BTW, why do you need to remove the plug? Is it possible to use a pump to drain from the top?
/ Rounded off drain plug #1,682
10 days without a post. How are we going to get the plug out if we do not keep our eye on the target? Memorial Day is almost here, begging for another Kando attempt.
/ Rounded off drain plug #1,683
Really, just find the closet 6 point socket, grind the plug till it starts on, hammer home and remove. 20 minutes work
/ Rounded off drain plug #1,684
Probably would be a good idea to use an impact socket. Brute force may break a standard socket. Lo and behold; after driving the socket on , the plug comes out only finger tight. Never under rate brute force. As my Dad used to say " if it don't go get a bigger hammer".
Closing on 1700.
Ron
/ Rounded off drain plug #1,685
the plug is 4 point, like the back end of a socket. it's MUCH harder to grind a 6 point by hand than it is to make a 4 point!.. I'd just put a good pipe wrench on the threads of the plug, and un-thread it!. and ALWAYS use a 4 point socket or wrench on the new plug!..
/ Rounded off drain plug #1,686
Could you please tell us where on the tool failed.
Thanks!
You are requesting information on a situation that happened 10+ years ago.
I am 78.
Can't remember what happened 10+ minutes ago.
Sorry!
/ Rounded off drain plug #1,687
Don't tempt me. Weather kept us out over Easter, weather still isn't cooperating. Ordered a pair of knipex to try out. They're scheduled for delivery on the 7th.
I suspect that plug is well beyond the capabilities of the Knipex.
It will not be possible to get enough leverage with the Knipex.
You will love the Knipex for many other uses though.
/ Rounded off drain plug #1,688
Put the Knipex on the plug adjusted for a good fit, squeeze, and slide a three foot long piece of thick wall small diameter tubing over the top handle to pull on.
If it can support a man standing on the top handle, it can take a torque multiplier pipe :thumbsup:.
/ Rounded off drain plug #1,689
You gotta love self explanatory pictures like that!
/ Rounded off drain plug #1,690
there's no way possible that the Knipex channel lock pliers could possibly outperform a pipe wrench!..
/ Rounded off drain plug #1,691
Noow yah done it...now yah gone and done it fer sure.......
Another 100 post on how Kando will have to set tractor on its side so he can stand on the knipex...!!!! :laughing: :D
/ Rounded off drain plug #1,692
Just doing my duty, I was #1700 :thumbsup:. :D
/ Rounded off drain plug #1,693
My thought EXACTLY!
/ Rounded off drain plug #1,696
The Knipex aren’t as beefy of a tool as a pipe wrench. When the cheater pipe comes out the winner is clear but using by hand the Knipex and the pipe wrench would be equal.
/ Rounded off drain plug #1,697
Have you used one? I take them any day over my pipe wrenches.
I don’t have any Knipex pliers but I’m quite certain they would work. Here’s some pics I just took of my 40 year old Channellock 410 pliers.
Pipe
Square head plug
Pipe
I stood on the tool with full body weight and it didn’t lose its grip. Couldn’t manage to balance myself to take the picture with phone at same time so you’ll have to take my word for it. Coordinated I’m NOT.
/ Rounded off drain plug #1,698
I'm sure the Knipex is a great tool, but the right size pipe wrench, adjusted correctly is incredibly strong, especially with a pipe over handle. A drain plug I'd use a small one, adjusted with a little slack. The harder you pull the tighter it grips.
I need to bring all pipe wrenches here from my home place as Grandad had 20-30 of them.
As a teen I helped a 400# 6'6" buddy remove his Buick differential plug with a pipe wrench, using me foot. I weighed 130# then. Your leg muscles are super strong. Friend and his 300# Dad had spent hours on it... I removed it in a few minutes.
They chased me all over the yard yelling obscenities...it was funny as he)).
/ Rounded off drain plug #1,699
At 400 pounds and 6’6” your buddy had bigger problems than a stuck diff plug.
I agree with you about the pipe wrench though.
/ Rounded off drain plug #1,700
I hope Kando gets the drain plug out soon. If not this thread is going to turn into a lot of pictures of people standing on knipex, channel locks, and other various tools just to show that the tool can support them. Sorry I couldn’t resist saying that, but that’s the first thing that popped in my head when I saw the 2 pictures of people standing on pliers.
2020 MACK P164T (A58214)
2020 MACK P164T...
More info coming soon! (A56859)
More info coming...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2008 Ford F-150 Ext. Cab Pickup Truck (A61568)
2008 Ford F-150...
2020 FREIGHTLINER M2 4X2 26FT BOX TRUCK (A59908)
2020 FREIGHTLINER...
832744 (A61166)
832744 (A61166)
