Rounded off drain plug
/ Rounded off drain plug #1,661
Ordered a pair of knipex to try out. They're scheduled for delivery on the 7th.
What size did you order?
Mine are the 12" length.
/ Rounded off drain plug #1,662
Don't tempt me. Weather kept us out over Easter, weather still isn't cooperating. Ordered a pair of knipex to try out. They're scheduled for delivery on the 7th.
The 7th of what month/year?
Hope they're not the 5 inch ones.
If we knew when they would be tried everyone could help by stopping whatever they're doing and go "uhhhh...uhhhh...uhhhh!".
/ Rounded off drain plug #1,663
I have been keeping up with the thread but I’m not sure if it has been mentioned but He could try to file, use a chisel, or use a grinder slowly to remake the head of the bolt for the next size smaller socket. Maybe the little amount of heat from the grinder would help it break loose easier.
/ Rounded off drain plug #1,664
Related -
My son was replacing the blades on his (bought used) zero turn today. After three pretty major attempts failed (including welding a socket to the bolt - he ended up just shredding the socket after applying "enough" force) he welded a box end wrench (the open end had already be cut off for some other project) to the bolt and got it out.
Desperate time = desperate measures.
I used a grinder a short while back to get two flat edges. Broke a small pipe wrench jaw on it, just rounds the corners with a larger one. Simply can't get enough grip on the flats with the way a pipe wrench works. Hopefully the flat jaw knipex works.
/ Rounded off drain plug #1,666
I've said this before but I would hire it out. The lack of experience in these matters leads to a lack of confidence and that combination can cause bigger problems. You can snap off the remaining head or who knows what. Either take to a shop or bring a guy from the shop to you. It's cheap money spent.
/ Rounded off drain plug #1,668
Creating the flat edges allowed the jaws to shear the corners off...pipe wrench jaws are designed to grip (round) pipes in an "arch" configuration which gives it exceptional strength to hold or apply torque...
I would at least try putting the jaws of a properly sized, quality wrench on the existing threads and not the damaged section of the plug...
Hang in there, you will get this done...we're all pulling for you...a couple of busy contributors to the thread may show some postpartum depression symptoms when you do get the plug out but you should have nothing to feel guilty about...we know you cando this...
/ Rounded off drain plug #1,669
Related -
Nice. The heat from welding on the box end wrench probably helped :thumbsup:
The existing visible threads are all of 1/4 inch or less of space to grip. The problem previously, as has been stated, is that there was never enough proper grip. Every attempt simply sheared more material off, hence moving in a different direction. Flat edges for grip with flat edge tools. Trying the pipe wrenches after grinding flats was an attempt on a slightly better surface to actually be able to tighten the jaws enough to not simply slide around or shear material.
/ Rounded off drain plug #1,673
At this point I would remove the cross bar since it's in the way. You can't do anything the way it is now.
Then I would wash the underside...engine cleaner, detergent, brush and hose it off. Let it sit a couple days. This way you've got a clean dry space to work.
Try a little heat, try those pliers. If it doesn't work, grind whatever is left flat with transmission case.
Carefully center punch it...exact center.
You can magnetize a drill bit by rubbing it on a strong magnet in one direction.
Start small working up to correct drill size for the tap. Magnetic drill bits will catch most shavings. Pan to catch fluid.
Tap it, use oil on tap.
Flush transmission. Start new plug by hand, kerosene should be fine. Pull plug and drain. Plug back in...a few quarts of new trans fluid...drain that.
Finally, new plug back in, tightened properly, new trans fluid, correct amount.
Reinstall cross bar.
/ Rounded off drain plug #1,674
Relax some of you's just been counting posts but this thread started on 03/30/2018 . FWI it took 107 years to almost complete The Tower of Babel !!! So imo most of us will see this completed in our life time if thread does not get closed (hope not) . I admire Kando for at least hanging in there with the thread, and chimeing in . Weaker men would have crumbled or hid !!! I said it before and will repeat it , whatever route you decide to keep attempting to remove drain plug wear gloves and eye protection . BTW this is my third post on this thread i believe ?
/ Rounded off drain plug #1,675
First attempt with (unwelded) wrench was applying heat with a torch. But maybe the third heat/cool cycle was a contributing factor. I mostly was amazed at how tenacious he was. Reminds me of myself in my younger days!
/ Rounded off drain plug #1,676
I can't speak for everyone but I never realized wrench flats were only 1/4th inch deep to begin with. Was that clear at the onset? If all nuts,bolts and plugs only had 1/4tr inch of flat,few if any tools,including late night infomercial tools would work if stubborn when it was new,much less after it's buggered up. It's no sin or crime to hire someone with more experience and tools.
Re-read. The visible threads are only 1/4 inch or less of space, from the pan to the actual square head itself. The plugs on this tractor, and my 5000 do not thread in completely. Some threads are still visible. The visible portion of threaded area is only about 1/4 inch. The square head itself is about 1/2 to 9/16 inch from the threaded portion to the end of the head. The head is what I ground flats on, as there is actually space to grip on that as it isn't up again the bottom of the tractor itself, unlike the threaded portion of the plug.
/ Rounded off drain plug #1,679
Kando said "visible threads" not "wrench flats". It is a pipe thread plug, the flats are rounded off. The 1/4 inch of threads that are showing are what he mentioned to grip.
This picture that was re-posted just 5 days ago, shows the threads:
/ Rounded off drain plug #1,680
Getting more and more too late​
Grind/file the whole exposed part of the plug parallel down to the root dia on just 2 sides. Dont cut into the root much. The root wrench surface is getting too small. Youre looking at twist off time.
Use a Crescent that will fully engage the faces to gauge // -- and then to take it out. You get 1 try.
1989 Corvette Convertible (A61574)
1989 Corvette...
2006 Toyota Sierra CE Van (A61574)
2006 Toyota Sierra...
ROANOKE S/A LOOSE LEAF TRAILER (A63291)
ROANOKE S/A LOOSE...
2024 John Deere 561M Heavy Duty Round Baler (A63111)
2024 John Deere...
2006 Utility 53Ft T/A Reefer Trailer (A64194)
2006 Utility 53Ft...
2005 Dodge Ram 1500 4x4 Crew Cab Pickup Truck (A61573)
2005 Dodge Ram...
