front mounted snowblowers HP required
/ front mounted snowblowers HP required #1
milkie62
upstate NY
Kubota M6800,Ford 801,MF 65, Kubota L305
There is no way I am trusting the dealer on what HP is actually needed to run a front mtd snowblower. My plan when I retire in 22 months is to have an enclosed cab tractor in the low 30 HP range for snowblowing 1300 feet of driveway and a 6 foot finish mower to keep roughly 8 acres of field groomed. I just bought a new 3500 Chevy that I will not put a plow on since I do not want to beat it and it will be my retirement truck. Just sold a 2013 Chevy and gave the plow to my son in law and daughter.I also do not need a FEL since I already have an M6800 with a FEL. Snowblowing and rear mower is all it will be doing. So lets hear from guys that do it and what kind of HP you use or wish you had. Thanks Ed
/ front mounted snowblowers HP required #2
NH TC33D, 33 hp and 26 at PTO. 5 ft. front mount blower and tractor barely notices blower at full capacity. 7.5 ft, 5 blade rear finish deck and again, tractor barely notices mower at full capacity. The 5 blade actually pulls very easily, but I borrowed the neighbors Woods 7 ft, 3 blade with high lift blades, finish mower and it pulled noticeably harder. I attributed the difference to the high lift blades.
/ front mounted snowblowers HP required #3
I recall reading the rule of thumb was 5 hp per foot of blower.*
Naturally a hydrostatic tranny is your best friend.
That being said I run a 60 inch on a 20 hp gear box tranny and have done so for some 8-10 years.
It is all about techniques that U soon learn.
*might have been for a rear installation.
Depending on the front mount drive method more HP might be required as some systems take rear power via a series of gears and long underslung shafts.
Others take drive power directly from a frt PTO or again others from the engine crankshaft.
Generally the RPM's of frt mounts are not the same as rear mts.
That sounds about right for what I have heard. I will be in no hurry to finish since I want a cab. Heavy sweatshirt,cup of Joe and some tunes playing and I will be happy. Same in the summer ----air on cup of ice tea and the same tunes playing as I mow.
/ front mounted snowblowers HP required #5
This was my TC33D with a 60" blower in deep, hard packed drifted snow (you could walk on top). I would slowly creep as it took lots of power.
/ front mounted snowblowers HP required #6
I have a 27 hp Kioti with hydrostatic tranny and a 5' blower on front. I believe it is about 24 hp at the PTO. The blower does a good job on dry snow, but on wet sloppy snot it plugs up. That is the main reason I took it off and will NEVER put it back on.
5 grand CDN takes it all away, blower front harness AND drive shaft with gear box. Buyer pays the shipping.
/ front mounted snowblowers HP required #7
Happened once on my ck4010. Last snowfall of the year. We has 353” locally this year, and probably 70% had already melted. The remaining snow was probably 80% water, and we got another snowfall on top of that, plus, the temperature was just above freezing.
The blower discharge plugged solid when removing the snow that slid off the garage roof in front of he door. I just gave up and put the tractor inside the heated garage to let the snow in the Chute melt.
If it’s any consolation, my F450 which weighs 10000 lb empty couldn’t move that compacted snow with its 10’ Boss plow either.
Blower worked great in normal snow, ant plugging in dense, high water content snow is an issue on walk behind snowthtowers too.
/ front mounted snowblowers HP required #8
It happened more often than not 4 years ago. I spent more time outside cleaning out the chute than I did blowing snow, it seemed like.
Since then I have only used the loader with a back blade and that works so good for me that the blower is never going on the Kioti again.
/ front mounted snowblowers HP required #9
Happened once on my ck4010. Last snowfall of the year. We has 353 locally this year, and probably 70% had already melted. The remaining snow was probably 80% water, and we got another snowfall on top of that, plus, the temperature was just above freezing.
If it痴 any consolation, my F450 which weighs 10000 lb empty couldn稚 move that compacted snow with its 10 Boss plow either.
I live 50 miles SSW of you and that last storm was something else. My L3540HSTC-3 and my L2195 (6') work great, I've only had it plug up on me once in 7 years. I find that if you keep the rpm's up to max it won't happen. In my case 2600 rpm.
My only problem with the blower is when it's too warm, around 30 deg or warmer the wet snow builds up on my auger shaft and after an hour or two the auger won't work, because the blades are almost cover with snow.
If the snow is wet I only do what's necessary and blow the rest when it gets cold. I like blowing snow when the temp is between 10 above and 10 below.
/ front mounted snowblowers HP required #10
Sounds like what I did 3 years ago! Cabbed L4060 and a new to me truck. I can't comment specifically on the front blowers hp requirements, but a 6' rear blower works fine on my machine with 32 hp at the PTO. Wet snow is going to be a problem with any blower. I know in a later response mowing time is a non issue, but if you go with 30 hp at the PTO or greater you can easily groom with a 7' mower.
/ front mounted snowblowers HP required #11
My Kioti CK 30 ( 23 PTO ) HST with 6' front mount blower and love it . It will throw snow 100 + feet with ease. My driveway is 1000 feet and also parking area and front of the house. No banking and job is nice and clean. Have a heated cab on top of that which is nice to have on those cold days.
/ front mounted snowblowers HP required #12
I have a mile long gravel driveway. Been out here in the sticks for 38 years now. First tractor had a 3-point blower. Worked great but was slow and I always ended up with sore shoulders and neck. Ten years ago I bought a brand new Kubota M6040. Got an ultra heavy duty rear blade and have never had troubles clearing the driveway with this unit.
Since I've always owned a 4WD vehicle - clearing whatever snow we get has never been a priority. I can always bust thru and get to the county road with no troubles.
Sooooo ....... I plow when & if conditions are at their best. I enjoy plowing when the temps are +10F to +20F. The snow is hard & dry and plows nicely.
UNUSED RAYTREE RMT48-48" HYD TRENCHER (A62131)
UNUSED RAYTREE...
2023 CATERPILLAR 289D3 SKID STEER (A62129)
2023 CATERPILLAR...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
UNUSED IRANCH MINI HYD THUMB (A62131)
UNUSED IRANCH MINI...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
John Deere 145 Lawn Mower (A63116)
John Deere 145...
