An easier way to refuel your tractor
/ An easier way to refuel your tractor #101
Hello All-
A couple weeks ago, I asked what people were using to refuel their tractors. I originally posted my question in the JD Owning / Operating forum, but was soon pointed to other forums where the same question had been asked several times. After combing through numerous threads, it was apparent I was not happy about the fuel filler location on my new tractor.
After reading numerous posts, it was pretty set on getting a 25-30 gallon gas caddy, however I did not like the fact that a 30 gallon caddy would weigh a lot and would be tough to load and unload from my truck. What I did like about the caddy was the fact that it had a manual pump which meant that I would not have to deal with keeping a battery around to power the pump.
While scouring the net, I came across the Flo Fast product on Global Industrial site and thought that this could be what I was looking for. When I went to Flo-Fasts website, I saw that they actually had a bunch of options to choose from, including some options that would work with my existing 5 gallon jugs. I ended up calling the company and speaking with the owner for a bit and although they were more focused on the boating and racing industry, I was told that their pumps and containers work just fine for diesel tractors.
Since my new Deere 4720 holds 15 gallons, I ended up ordering their 15 gallon tank, heavy duty cart, and professional pump. The parts arrived this past week, and I finally had a chance to try it out. The fuel jug is pretty thick, yet it is easy enough to toss into the back of my truck and fill it up. Since we are only talking about 15 gallons, I like the fact that I don't have to worry about fuel sitting around for too long, especially during winter. The cart is solid, and has no issues moving the filled container around. As an added bonus, it folds up nicely and does not take up a lot of space. The pump moves up to 8 gallons a minute, so you have to be careful or else it is somewhat easy to overfill your gas tank (ask me how I know this). While using the system, there were no leaks which kept everything nice and clean.
About the only downside I can see to this system is that the fuel jug weighs about 100 pounds when full, so it is pretty dang heavy to lift out of my truck bed. If I were to do this again, I would probably consider going with the two 7.5 gallons cans as those will be much more manageable. Depending on which package you choose, the options can get pricey, however the quality is there, so you do get what you pay for. Overall, I really cant complain, and am very happy with this purchase (and so is my back and shoulders).
Well, there you have it. I have gotten so much good information from this forum ever since I purchased my first Deere 4310 back in 2002, so I hope that this review / information will help some of you out there who are also looking for a smarter / better way to get work done using our tractors.
Dano-
You have a tractor with a bucket. Slid the full fuel tank from your truck bed into the bucket of the tractor. No lifting required. I do this with my 30gal fuel tank.
Steve
/ An easier way to refuel your tractor #102
If you are stuck using normal 5 gallon jugs with the typical safety spouts that take forever to dispense 5 gallons there is a cheap and easy trick to help it breath and flow better. Get a tire valve stem for a tubeless tire and remove the guts from it. Drill a hole and install the valve in the back side of the jug where the vents use to be. Remove the valve stem cap to let it breath and flow better when filling up. It took mine from about 6 minutes to 2 minutes to empty a 5 gallon jug.
How to install a vent in a plastic gas can - YouTube
best idea ever!
/ An easier way to refuel your tractor #105
go to Ebay and search gas can vent, or look here
2 Yellow Fuel Gas Can Jug Vent Cap Chilton Brigg Rotopax Gott Rubbermaid Anchor 6527313;)9 | eBay
/ An easier way to refuel your tractor #106
Why lift those 5 gal cans at all when you can use a pump like this:
https://www.amazon.com/gp/product/B01HOXQ5E0/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
The hose is long enough to reach the hood fill port with the can on the ground. Takes less than 2 minutes to empty the can. The pump uses 12VDC or 110VAC and is rated for gas or diesel.
/ An easier way to refuel your tractor #107
Been doen it that way a long long time. And those valve stems make a excellent primer port for those briggs that are a little difficult to start. To put a squirt of gas in the carb throat don't need to remove the filter cover for this hard starting twin.
/ An easier way to refuel your tractor #108
Any method where you don't end up with spilled Diesel or it on your hands is a GOOD way.
/ An easier way to refuel your tractor #109
12ft 9in Altec Service Bed (A61165)
12ft 9in Altec...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
2011 AUXILIARY POWER UNIT (A60736)
2011 AUXILIARY...
We do NOT accept credit cards as payment. (A60462)
We do NOT accept...
TANK MANIFOLD (A58214)
2019 CUSHMAN HAULER PRO ELECTRIC GOLF CART (A58375)
2019 CUSHMAN...
