KX41 2V Hydraulic Problems
/ KX41 2V Hydraulic Problems #1
Muskoka00
Muskoka, ON
MF 1552
Having issues with my KX41 2V of jerky operation of boom and rotating at fully open valves. When operating slowly no jerking. Have changed fluid and both filters. Any suggestions?
:confused:
/ KX41 2V Hydraulic Problems #2
:confused:
Oil and filter change is never wrong, but what you need to do is get the hydraulic diagram of this machine, and see what boom and rotating have in common.
Your Kubota dealer might be willing to copy the diagram on a USB stick.
If you can post the diagram here, I am sure you will get suggestions.
Is there a possibility that air is introduced in the system? Check for leaks with engine off.
/ KX41 2V Hydraulic Problems #3
Did you change fluid and then the issue or vis versa?
300 GAL WATER TANK (A68842)
300 GAL WATER TANK...
2012 CTS BELLY DUMP (A67714)
2012 CTS BELLY...
2007 (INOPERABLE) INTERNATIONAL DURASTAR 4300 (A67714)
2007 (INOPERABLE)...
2011 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2011 CHANDLER TRI...
2005 FORD TAURUS CAR (A66091)
2005 FORD TAURUS...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
