Rounded off drain plug
/ Rounded off drain plug #1,522
When a new Pope is elected, they send up white smoke. When the drain plug comes out, I think Kando should tip up some pallets in his field.
/ Rounded off drain plug #1,524
Boats were mentioned above, the boat we had was equipped with a fitting in place of oil plug that had a small pipe attached to it that went up beside the engine. It had a cap on it that was removed when it was time to change the oil, just sucked it right out, pulling from the normal drain in pan, so it got everything out that pulling the plug would have.. of course there are many different systems in place.
/ Rounded off drain plug #1,525
I think some time back I wondered if this thread would get to 2000 posts before we figured it out. So we have time. I bet it will be some hairbrained idea that wins the prize.
/ Rounded off drain plug #1,526
Like go to town and get a replacement drain plug, hit the old one with a propane torch after wipedown, and then put a pipe wrench of suitable size on it and turn the correct direction to back the plug out and be done with it? :) Something like that?
/ Rounded off drain plug #1,527
I agree. With heat applied to the plug grip would not be as critical.
/ Rounded off drain plug #1,528
I am not sure, Kandos plug is different than anything TBN has dealt with before, it is not an ordinary pallet,,,,, uhhh, I mean... plug. :duh: :duh:
/ Rounded off drain plug #1,529
Why does idiocy abound? and why do some folks see forum queries as contests?...it ceases to amuse me...
/ Rounded off drain plug #1,530
:thumbsup:​
/ Rounded off drain plug #1,532
Sorry /pine you will need to amuse yourself. :wave:
/ Rounded off drain plug #1,533
Why do you keep reading them if you find them so offensive? To me that's the biggest mystery of all.
/ Rounded off drain plug #1,534
What I said was a (paraphrased) sublimated expression that should have read "never ceases to amuse me"...
/ Rounded off drain plug #1,535
Hate to detract from the topic but I'm curious why some folks like to play "hall monitor"...especially when they cant see the enigma for the mystery...LoL...
/ Rounded off drain plug #1,536
From here it seems that you are the "hall monitor"... but whatever floats your boat.
/ Rounded off drain plug #1,537
/ Rounded off drain plug #1,538
Okay another hair brained idea since you are betting...
1. Drill a hole through the side of the plug.
2. Drive a hard pin through the plug that extends a bit on both ends.
3. Grind a couple of notches in a socket that fit the pin.
4. Put a ratchet and cheater bar on it.
5. Break the socket.
Oh well... next?
/ Rounded off drain plug #1,539
Thank you for your contributions to the post count. Much appreciated :thumbsup:
If you can think of a way to get the plug out, please chime in. :thumbsup:
/ Rounded off drain plug #1,540
Oh well... next?
Impact socket might not break?
Vermeer SW2500 (A62177)
Vermeer SW2500...
New/Unused Quick Attach Auger with 2 Bits (A61166)
New/Unused Quick...
2014 John Deere 5075E Tractor (A61166)
2014 John Deere...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 Bobcat T550 Compact Track Loader Skid Steer (A61567)
2014 Bobcat T550...
2021 CATERPILLAR 259D3 SKID STEER (A62129)
2021 CATERPILLAR...
