Shortening folding ROPS on BX24
/ Shortening folding ROPS on BX24 #81
Thanks for sharing.
I think I read this once and have always attempted to abide by it:
If the ROPS is down, don't wear your belt.
If the ROPS is up, make sure the belt is on.
I forget where I read it. I don't even know whether it's good advice.
I've heard it many times and I believe it to be sound advice. Think about it.
/ Shortening folding ROPS on BX24 #82
I believe the best advice is to never allow yourself to get into a situation where either would matter. Operate as if neither was there.
/ Shortening folding ROPS on BX24 #83
Great idea. Air bags and seat belts are stupid too.
/ Shortening folding ROPS on BX24 #84
Many are already doing that. You need only to read all the posts about them hitting their garage with the ROPS to see it. :thumbsup:
/ Shortening folding ROPS on BX24 #85
I started this thread and just now realized I never did a completion post. Sorry about that. I do not have a welder so I cut three inches(?) off the bottom and redrilled the holes. So you can get it shorter by either method; cut the top and reweld or cut off the bottom and redrill. I am glad I did and I don't think I have lowered it since I shortened it. And I do wear my seat belt at all times now.
Doug in SW IA
I know this is an old thread, but would love to see the finished results. With my rops up, I'm about 2" shy of clearing my garage entrance on my bx2380
/ Shortening folding ROPS on BX24 #86
Yeah I learned the hard way. :confused2: The good news... it took me one lesson. I don't regularly park mine in my garage so it is not a big issue to lower them occasionally when I pull her in for service. It would be a pain to mess with the ROPS on a regular basis but I hate the idea of shortening them.
Sorry it took me a while to get around to pictures. But it really doesn't look and different, other than being shorter.
I did have some minor alignment issues that a little file and grinding work took care of. But keep in mind that I did this with it on the tractor and I used wooden blocks as my drill guide. If I were to do it again I would probably remove it from the tractor and use my greatly improved drill press. I have absolutely no reservations about the safety issues. My modification was pretty minor. Now that my ROPS is shortened I leave it up all the time and I wear my seatbelt every time. So overall my safety level has gone up.
Doug in SW IA
/ Shortening folding ROPS on BX24 #88
I got off easy. I had my tractor first, so that when I built my garage I made the wall studs 9 feet so that the overhead door would be high enough to accommodate the Rops on my BX25. I garage my tractor all the time, and it would’ve driven me crazy if I had built the garage first, and then found out that the clearance for the tractor was too low!
/ Shortening folding ROPS on BX24 #89
^^ I messed up when I added onto my shed. It had a roof with no peak, slanted from one end to the other whatever style that's called. When I added to it I thought about 12' posts but figured that 10' posts would be enough to continue that slope to the new wall. It was for the purpose at the time, before I had the SCUT. What happened is that the door allows the ROPS to clear by about a half inch. But the next rafter is a bit lower for some reason (settling maybe) and does not clear. So I can only get the ROPS in 24" without lowering it, not enough to clear and close the shed door. Had I used the 12' Posts as I originally planned, I would be fine.
It'll work out OK because there really isn't enough room for everything I had then, let alone now, so I have to change it all again.
2016 TEXT 26ft T/A Dovetail Flatbed Equipment Trailer (A59230)
2016 TEXT 26ft T/A...
2018 CATERPILLAR 320 EXCAVATOR (A62129)
2018 CATERPILLAR...
2019 FORD F-250 XL EXT CAB TRUCK (A59823)
2019 FORD F-250 XL...
2024 Linx UT357712T (A60463)
2024 Linx...
(INOP) 1998 FORD F-SERIES FLAT BED TRUCK (A59823)
(INOP) 1998 FORD...
KBH Tender Trailer (A56438)
KBH Tender Trailer...
