best gooseneck hitch
/ best gooseneck hitch #1
DanielPalmerston
McCormick X7.690 P6-Drive
Looking at a gooseneck hitch for my truck? What are the considerable things to choose the best gooseneck hitch?
/ best gooseneck hitch #2
I've got the B&W turn over, in both my duallies. No plate or ball in the way when you need to haul sheets of plywood, etc.
/ best gooseneck hitch #3
ditto.........B&W
/ best gooseneck hitch #4
Another B&W here, use it for towing trailers, then throw a fifth wheel adapter to tow the camper
/ best gooseneck hitch #5
B&W hands down, have them in both my F-350's. Top notch quality, flawless installation(if you read the book, and follow it, hint, hint)
/ best gooseneck hitch #6
We have B&W Turnover hitches in both trucks now and have had several over the years.
For those not familiar with how they work:
/ best gooseneck hitch #7
I have the same. B&W turnover ball. I'm not going to say "It's the Best", as in the "best one" made, but I have been happy with mine. I also have the 5th wheel companion hitch for it, that drops into the hole when you take the ball out. 3 yrs now, no complaints.
/ best gooseneck hitch #8
I favor the B&W. I have a B&W in my 08 and the factory Curt in the 17. I had a B&W in my 03 I traded in on the 17. The Curt ball doesn't always want to release without WD40 and a tap from a hammer. With the Curt you have to remove the chain hooks to have a flat bed, the B&W chain hooks slid down into the bed.
/ best gooseneck hitch #9
I've had a few through the years.
Currently, a Colibert (CE Brand) in the '03 F-350
And, the B&W in the '16 F-250. Just for the convenience and ease of installation, I vote for the B&W. This is my second B&W. I don't plan to buy anything else again.
/ best gooseneck hitch #10
My dually has the B&W turnover Niall, companion fiber hitch, and a class V receiver hitch. All are very high quality and easy to use. B&Wis always my first choice.
/ best gooseneck hitch #11
Una goose hitch is my choice,had one in my F250 and now one in my F350. Didn't like the B&W rod setup. Both of mine were professionally installed, so don't know how easy they are to install.
/ best gooseneck hitch #12
I think the one in my truck is a Draw-Tite, much like te B&W turn-over ball in design and operation, a little bit cheaper price. Works fine for my limited use.
/ best gooseneck hitch #13
I did the install of a B+W in a brand new 2001 Chevy Dually. The hardest part was cutting a honk'n big hole in a pristine bed. The B+W has well served for 18 years with no issues. Hauling heavy trailers, keep the ball greased or the ball will get galled.
/ best gooseneck hitch #14
Back when I installed one in my new truck, I put the holesaw in my drill press and ran it thru a piece of sacrificial plywood. Then I have a perfect, large template. Remove the pilot bit from the holesaw and place the hole in the plywood exactly where you want the hole in the bed and stand on the plywood while you drill. You will have good control of the saw as it chatters thru the corrugations and make a perfectly round hole.
/ best gooseneck hitch #15
My ‘16 F-350 has the factory reese gooseneck hitch. No complaints with how it works, its just that when you are not towing and want to use the bed, you have to take the greasy ball and safety chain fittings and put them...where? Then hope you dont leave them at home when you need them or lose something. I installed a B&W in my Nissan, much easier. Done with the ball, just flip it and you got your bed back.
What do you think about curt gooseneck hitch? They seem to have a good review in the market.
/ best gooseneck hitch #20
Yep. What he said.
Just get the B&W turnover ball hitch for your truck.
2016 Autocar Xpeditor T/A Side Loader Garbage Truck (A61573)
2016 Autocar...
2016 Ford Taurus Sedan (A61574)
2016 Ford Taurus...
2016 Chevrolet 2500 HD 4WD (A63689)
2016 Chevrolet...
CHEVROLET SUV (A64280)
1987 International 1954 Elliott ECE 3-65H Telescopic Boom Lift Truck (A61573)
1987 International...
16ft. Teak Wood Table (A61574)
16ft. Teak Wood...
