best gooseneck hitch
   / best gooseneck hitch #11
Una goose hitch is my choice,had one in my F250 and now one in my F350. Didn't like the B&W rod setup. Both of mine were professionally installed, so don't know how easy they are to install.
   / best gooseneck hitch #12
I think the one in my truck is a Draw-Tite, much like te B&W turn-over ball in design and operation, a little bit cheaper price. Works fine for my limited use.
   / best gooseneck hitch #13
I did the install of a B+W in a brand new 2001 Chevy Dually. The hardest part was cutting a honk'n big hole in a pristine bed. The B+W has well served for 18 years with no issues. Hauling heavy trailers, keep the ball greased or the ball will get galled.
   / best gooseneck hitch #14
Back when I installed one in my new truck, I put the holesaw in my drill press and ran it thru a piece of sacrificial plywood. Then I have a perfect, large template. Remove the pilot bit from the holesaw and place the hole in the plywood exactly where you want the hole in the bed and stand on the plywood while you drill. You will have good control of the saw as it chatters thru the corrugations and make a perfectly round hole.
   / best gooseneck hitch #15
My ‘16 F-350 has the factory reese gooseneck hitch. No complaints with how it works, its just that when you are not towing and want to use the bed, you have to take the greasy ball and safety chain fittings and put them...where? Then hope you dont leave them at home when you need them or lose something. I installed a B&W in my Nissan, much easier. Done with the ball, just flip it and you got your bed back.
What do you think about curt gooseneck hitch? They seem to have a good review in the market.
   / best gooseneck hitch #20
Yep. What he said.
Just get the B&W turnover ball hitch for your truck.
2025 Swict 66in Bucket Skid Steer Attachment (A53421)
2025 Swict 66in...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2016 FREIGHTLINER CASCADIA DAY CAB (A54607)
2016 FREIGHTLINER...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
UNUSED WOLVERINE GB-11-72W 72" HYD GRAPPLE BUCKET (A54757)
UNUSED WOLVERINE...
