best gooseneck hitch
   / best gooseneck hitch #11
Una goose hitch is my choice,had one in my F250 and now one in my F350. Didn't like the B&W rod setup. Both of mine were professionally installed, so don't know how easy they are to install.
   / best gooseneck hitch #12
I think the one in my truck is a Draw-Tite, much like te B&W turn-over ball in design and operation, a little bit cheaper price. Works fine for my limited use.
   / best gooseneck hitch #13
I did the install of a B+W in a brand new 2001 Chevy Dually. The hardest part was cutting a honk'n big hole in a pristine bed. The B+W has well served for 18 years with no issues. Hauling heavy trailers, keep the ball greased or the ball will get galled.
   / best gooseneck hitch #14
Back when I installed one in my new truck, I put the holesaw in my drill press and ran it thru a piece of sacrificial plywood. Then I have a perfect, large template. Remove the pilot bit from the holesaw and place the hole in the plywood exactly where you want the hole in the bed and stand on the plywood while you drill. You will have good control of the saw as it chatters thru the corrugations and make a perfectly round hole.
   / best gooseneck hitch #15
My ‘16 F-350 has the factory reese gooseneck hitch. No complaints with how it works, its just that when you are not towing and want to use the bed, you have to take the greasy ball and safety chain fittings and put them...where? Then hope you dont leave them at home when you need them or lose something. I installed a B&W in my Nissan, much easier. Done with the ball, just flip it and you got your bed back.
What do you think about curt gooseneck hitch? They seem to have a good review in the market.
   / best gooseneck hitch #20
Yep. What he said.
Just get the B&W turnover ball hitch for your truck.
2014 Ram 1500 Crew Cab Pickup Truck (A55788)
2014 Ram 1500 Crew...
UNUSED LANDHONOR PF-11-3500G PALLET FORKS (A54757)
UNUSED LANDHONOR...
1996 Ingersoll-Rand VR642C (A47477)
1996...
1983 Case 580D (A47477)
1983 Case 580D...
UNUSED (2) 5200# DROP AXLES W/ BRAKES (A54756)
UNUSED (2) 5200#...
