Rounded off drain plug
/ Rounded off drain plug #1,441
For some reason ever since this post started over a year ago when I see it I think of the sloth. It takes them a month to digest a single leaf. They climb down out of their tree once a WEEK to poop. When they finally poop they say the expression on their face is pure bliss, since in that one event they lose a third of their entire body weight.
So it will be here...that fateful day when that plug FINALLY comes out, ever sooooo s-l-o-w-l-y turned until at last...a crowd of bystanders cheering, balloons being released, confetti and streamers floating down.
Traffic will be backed up for miles. Every major TV, Radio, newspaper and magazine reporter will be there, as well as all the ambulances and medical staff attending to those who have fainted.
Last but not least, even now, the Zambelli Fireworks Company is on standby, several tractor trailer loads of supplies packed to the hilt just for this momentous occasion.
/ Rounded off drain plug #1,442
And I have thought some of my chits were good.......
/ Rounded off drain plug #1,445
It痴 so long ago I do not remember what the plug drains......
/ Rounded off drain plug #1,446
Itç—´ so long ago I do not remember what the plug drains......
It could change everything, we may need to start the suggestions for Kando over. It is no wonder the plug is still in. :confused3:
/ Rounded off drain plug #1,447
I haven't been here in a while. Did he use a mag drill and rota broach to make a new drain hole yet? I figured he could use a rubber boat plug as a stopper, the kind with a wing nut in the middle.
/ Rounded off drain plug #1,448
For those who are curious, I've had good luck with these. Read somewhere they're made by the same company who also makes them for some of the tool truck brands. Description says good for tight spaces, which is false. You need a much larger socket than whatever you are trying to remove..
/ Rounded off drain plug #1,449
Here's the link since I needed 3 posts.
Sears.com
/ Rounded off drain plug #1,452
And I think we have enough wingnuts.:)
/ Rounded off drain plug #1,455
So many posts now; I have lost track whether this method was ever explored:
1. Grind a flat spot on the face of the bunged up plug.
2. Find short piece of tube that just fits over the bunged up plug.
3. Get a transfer punch, same size as tube interior, and hit with a hammer to have a new center.
4. Drill out a convenient size hole to allow fluid to drain and let drain overnight into a pan.
5. Continue to drill out the bunged up plug till only a shell remains in the threads, caution, do not get into the female threads.
6. Using a small cape chisel and hammer and peck out the residual shell.
7. Using proper size tap and clean up the threads.
8. Now using one of the many ideas , in this thread (your choice), on replacement plugs and install it.
8. Fill the reservoir with the proper fluid.
This process has never failed me in 80+ years; on all types of machinery.
You are now back in business. DO NOT REPEAT the scenario that started this Thread. We will not have the patience exhibited by all your TBN friends and their long suffering again.
Ron
/ Rounded off drain plug #1,456
Has any thought been given to turning the tractor upside-down and draining the oil out the fillhole ???
I mean every other option you can think off has been suggested.:cool2:
/ Rounded off drain plug #1,457
As has that :D
/ Rounded off drain plug #1,458
What about filling the transmission with water to float the oil out and then boiling off the water. I don’t recall reading that suggestion.
/ Rounded off drain plug #1,459
^^ That one is a new idea. Boiled tractor :confused:
/ Rounded off drain plug #1,460
Ron
You said 'bunged' three times. :scratchchin:
You must like 'bung'.
2017 TAKEUCHI TL12R2 SKID STEER (A64279)
2017 TAKEUCHI...
CASE INTERNATIONAL 3330 HI-CYCLE SPRAYER (A63291)
CASE INTERNATIONAL...
CASE INTERNATIONAL 183 - 6R DANISH TINE CULTIVATOR (A63291)
2013 Honda Pilot SUV (A61574)
2013 Honda Pilot...
5' Bush Hog Mowing Deck (A62613)
5' Bush Hog Mowing...
1770 (A58375)
1770 (A58375)
