Grading Scraper blade - how wide?
/ Scraper blade - how wide? #41
I got lucky, found a local who wanted to get rid of a used one for half that. :) Just keep watching craigslist and facebook farm equip groups. Never know what you'll find.
/ Scraper blade - how wide? #42
I made the mistake when buying my blade, too narrow!
However I rectified by adding 6 ins to each end and a new cutting edge.
Later I added a shelf in order to add weight.
Fortunately I can rotate for maximum usage and often level material by grading in reverse as then the 4 wheels ore on a level surface and there are no ups and downs, AKA woopie doos!
/ Scraper blade - how wide? #43
I run my dad's old 8 foot Super Rhino. It was considered a heavy duty blade when sold back in the 60's. It will not cover my tracks if tilted to 45 degrees but has an offset feature that allows moving it to the side. It was a top of the line blade back in the day and does a great job. Weight is your friend in blades and the more they weigh the more they cost. Just as a comparison the medium duty 8 foot blade listed for the Taylor Way weighs in at 510#. It is a good decent blade. The Super Rhino that I use is listed at 760# with a 3" kingpin. Oosik's is heavier than mine.
/ Scraper blade - how wide? #44
One comment I have not seen mentioned is you need to have plenty of tractor weight no matter what the blade width. Any blade at a steep angle will try to push the tractor side ways. Especially in deep snow with slick conditions underfoot, a steeply angled blade will push the tractor sideways, often into the ditch. Been stuck from that too many times! It will also happen with dirt, but not as easily since there is usually more traction for the wheels. Weight is important for the blade, but perhaps of equal importance is having a rear trailing wheel on the blade to help maintain the proper height. On a gravel road that will give a very smooth finish job, evenly distributing the gravel. W. Jones
/ Scraper blade - how wide? #45
Turbys, what is the weight of your tractor you put this Super Rhino on? I'll just be grading gravel on my driveway...#34 and crusher run, and it would go on my 4100 pound 62 hp L6060. I don't think I'll have any problem with a 1000 pound blade, but I welcome anyone's input.
/ Scraper blade - how wide? #46
To me, the Land Pride RBT3596 is a perfect match for an L6060.
/ Scraper blade - how wide? #47
Thanks Brian... always helpful, as usual. Funny, I was leaning toward the same thing basically...but a no-hyds Landpride RB3796. I plan on using one of your exquisite top & tilt kits, so I don't think I need the hydraulic grader (RBT).
Do you think a 96 versus a 84" is better? I will almost exclusively use it at 45 degrees. My L6060 with R4 tires is 72" wide. The RB3784 at 45 degree blade angle is 59" wide (~6 inches inboard of both wheels), but the RB37 can offset by 26" left or right. So, at full offset, that 59" width would stick out past the right wheel about 20". Gravel would be dumped about 39" in from the edge of the driveway...a second pass could bring it further to the center if needed. But maybe its better to have that extra reach with the 96"..at 45 degrees is 67" wide. Yeah, we are only talking 8" difference, I know. What do you think...it would be for a 10-12" driveway about half a mile long. RB3796 weighs 665 pounds. RBT3596 weighs 735...probably mostly from the extra hydraulic actuators.
/ Scraper blade - how wide? #48
Actually that weight is taken with the manual adjustors. The RBT35 series has 30" of offset capability, a HUGE plus in my mind. Several of my customers have gone with 96" blades and all seem to be happy. I think that you will find that an 84" blade is just to narrow for your tractor's all around use. Can you get by with a 7' unit, absolutely, but I'm pretty sure that you would be happier with an 8' model.
I know that I went from an 8 footer with 24" offset capability on my bigger tractor to a 9 footer with 35" offset capabilities, what a difference. Hardly ever have to offset anymore, but when I do I have all I ever need. :cool::thumbsup:
I believe that you will find that it would be very nice to have the hydraulic angle, I find myself changing the blade angle quite a bit. But that might just be me and my situation.
Easy enough to get by with manual adjust tilt, basically don't even need it when you have T&T. With manual adjust offset you will find that you only use it when absolutely needed vs when it would just be easier to have the blade offset a little.
Just my :2cents:, oh and be sure to get the skid shoes. ;)
/ Scraper blade - how wide? #49
Thanks Brian. Weight...yeah, that makes sense. The RBT looks a lot beefier. It's about a foot longer too. And I just noticed that the RBT has 50 degrees of max angle, compared to 45 for RB. Maybe you are right....
Assuming TNT and 3 hydraulic valves on my tractor, I would have one open valve. Do you change your offset more, or your blade angle more? In other words, if you only had one hydraulic option, blade angle or offset? My use is mostly pulling rock back into the center of the road. I'd think I'd want 45 degree blade angle all the time for that, but not sure.
Why the skid shoes?
/ Scraper blade - how wide? #50
Why the skid shoes?
MAYBE:rolleyes: If you look close, you can see that I have( until just recently) only had a single hydraulic on my LP RBT45108. It was on the blade angle adjustment. I have over a mile of road to maintain and about half of it has curves going left-right. In those curves I often adjust the blade angle. I will also say that the amount of angle I have the blade set at changes with the moisture content in the ground.
With what I grade most of the time, offset typically is not required, so to answer your question, angle is changed waaaay more than offset is used.
I honestly can't see any reason that offset would EVER be used more than blade angle. Just because you offset the boom does not mean that the blade angle does not need to be changed. You would still need to change the blade angle with the boom offset. but it seems common that people have the offset cylinder in place and leave the angle adjustment to be manual.
Skid shoes just make life easier and for the most part prevent the corners from gouging if-when the blade tips.
If you go this way, purchase the blade with no angle adjustment at all and get the cylinder from me. I can provide a 3 1/2" dia welded cylinder with a 1 3/4" dia rod with the proper length hoses and couplers shipped to you for less money than what LP charges for their tie rod cylinder and hoses that are to long with no couplers.
/ Scraper blade - how wide? #51
Monster blade. Wow. Hadn't thought about the angle changing with offset. But when do you use flatter blade angles? I don't see the use for them...at flatter angles I'd rather use a box blade or grading plane. But I defer to you, because I really know less than 1% of what you do.
Check this place out...made right here in GA. Their 96" weighs 827#, $2200 without hyds. What do you think? Seems well built. I could get this one and buy the hyds from you.
Dirt Dog Model 9108, 96" Rear Blade
/ Scraper blade - how wide? #52
I typically run my blade between 30*-45*. Really depends on what I'm doing and again, moisture content.
That Dirt Dog is a good model at a GREAT price. About $2500 for the base blade, skid shoes and blade tilt pin adjuster. They get your attention with that $2200, but that is for the base unit only, NOTHING ELSE.
I have contemplated getting an 84" Dirt Dog unit for my smaller tractor. Down fall is, it only has 20" offset capability. The plus side is it is heavier than the LP unit. The 30" of offset that Land Pride has with their RBT35 series is a HUGE plus with this size-weight of blade in my mind. In reality 20" offset is probably fine, it's just nice to have that little bit more if-when that occasion arises.
As far as the cylinders with hose kits from me, we should be in the 5-$600 range for the 2-16" stroke cylinders and hose kits. :thumbsup:
/ Scraper blade - how wide? #53
My T4.75 with loaded rears and FEL should be somewhere between 9000 and 9500 pounds. I'm guessing that off specs and have not weighed the unit to verify.
/ Scraper blade - how wide? #54
What model are you talking about? I don't know of any heavy duty blades with variable tilt, angle, and offset positions that you can also turn it completely backwards without unbolting everything.
Everything Attachments "Xtreme Duty Scrape Blade",.... but not hydraulic
/ Scraper blade - how wide? #55
AGTacticle - both of the blades I had/have were/are 96". My rear tires are 80" - outside to outside. Takes that wide a blade to get a descent offset when plowing snow. Allows me to - offset, stay 24" from the edge of the driveway - plow snow completely off the edge of the driveway. There are a few places on the driveway where "off the edge" is an 8 to 10 foot drop.
Summer maintenance - I only offset to clean out the ditches. Otherwise, it's angled only and a straight pull behind the tractor
When crowning - I tilt to the max and angle. When the blade rests down - it is still, more or less level. However - once I get going it's obvious there is more down pressure/weight/whatever on the outside edge. It cuts and piles to the center of the driveway.
As MtViewRanch says - blade size/weight depends upon what you want to do - moisture content - type of material you are working with. My driveway has just enough silt, clay and volcanic ash - - turns to rock hard concrete in the summer.
My first blade - Land Pride GS3596 was 96" & 565 pounds. Far too light for attacking my concrete-like driveway in the summer. My current blade - Rhino 950 is 96" & 1100 pounds. I have to be careful or all the driveway could end up in the ditch.
The Rhino is wider than Kubota recommends( 72" ) but lighter than they recommend(1200 pounds). This crazy situation ( weight vs width ) follows thru consistently on all the implements listed in my Owners Manual. I use but don't abuse. So far the heavy rear blade has caused no damage to the 3-point ( 4 1/2 years + ). And I've "pulled" sufficient loads of dirt to cause all four wheels to spin.
The situation I'm most cautious of - hooking something (root or bedrock) with the rear blade and causing an instant dead stop. To help prevent this situation - when plowing unknown areas I will tilt the blade - top-forward, cutting edge - trailing. This way if I encounter something - the blade will bounce over rather than catching.
/ Scraper blade - how wide? #56
I have 3 back blades to work with;
a 9 foot Deere it's all manual to spin the blade 180 I just have to pull the pin and turn it.
I just picked up an old Allied 10 footer it will have the hydraulic angle, and eventually full hydraulics,
to rotate the blade 180 all that needs to be done is pull the pin on the rod end of the cylinder and rotate.
The Ford is an 11 footer with full hydraulics and it's the same one pin on the angle cylinder and spin the blade 180 repin and go.
/ Scraper blade - how wide? #57
I pull a 7ft with my 2400H.
/ Scraper blade - how wide? #58
Brian (MtnView)...ever try using a good rake instead of a blade for gravel road maintenance? I don’t have any fines...its all #34 rock. Anyone else have any input on this?
/ Scraper blade - how wide? #60
Brian (MtnView)...ever try using a good rake instead of a blade for gravel road maintenance? I don稚 have any fines...its all #34 rock. Anyone else have any input on this?
I have only used my rake on the roads for final dressing, not for actual maintenance. I would think that a good heavy rake rake would work very well. I have not had a reason to use mine for that task.
In fact my rake has been apart for many years awaiting time to build a good hitch frame for it and install hydraulic offset and angle. :cool:
Someday when I have some spare time. ;)
2016 CATERPILLAR 303.5E2 CR EXCAVATOR (A65053)
2016 CATERPILLAR...
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A64556)
2020 Mack Anthem...
JOHN DEERE 4730 SPRAYER (A64278)
JOHN DEERE 4730...
2005 Stertil Koni ST-1082R 18000lbs 4-Post Auto Lift (A61572)
2005 Stertil Koni...
1995 Bulk 307 SS Insulated 6,500 Gallon T/A Chemical Tanker Trailer (A64194)
1995 Bulk 307 SS...
2016 John Deere 85G Midi Excavator (A64553)
2016 John Deere...
