problems with new kubota bx23s
/ problems with new kubota bx23s #1
rogerwrob
Member
ks
kubota
I got this tractor a month ago . It has 7.8 hrs on it.last Thursday the seat release lever fell off. On Friday I put it back on and found a electrical connector that looks like it was done by a kid. The wire is so tight I cant move it and fell like this is going to be a problem down the road. Well I started digging with the back hoe and oil started spraying out.The dealer is coming out to bring replacement parts for the seat and I will ask him about the oil leak and the electrical connector then. I will post pics of the connector and my question is would this have happened at factory or the dealer ship? Thanks Roger
/ problems with new kubota bx23s #2
That is hilarious... you are right -- looks like some kid did it.
Hopefully the dealer will repair with like OEM. Trust me, you don't want seat switches haunting you down the road.
/ problems with new kubota bx23s #3
My guess is that the seat and wiring issues are factory. The backhoe leak I would call a dealer issue. My reason for that is my experience with my 2650. I bought the tractor, backhoe, LP grapple, LP back blade and rotary cutter at the same time. When I picked it all up, the rubber guard was missing from the cutter. When I got home I discovered the front grill guard was not installed behind the loader. When I installed the grapple and opened and closed it hydraulic fluid sprayed freely from one of the hydraulic connectors. Later, when |I got to use the backhoe at my camp, virtually every flare fitting was loose and it leaked hydraulic fluid everywhere at the back of the backhoe frame. The dealer was not thrilled about me complaining and only gave me a gallon jug of hydraulic fluid after several calls and visits. The biggest problem is that I bought the tractor to use at my camp - 3 1/2 hours away from the dealer. Hauling it back and forth or having the dealer come fix it were not options. I trusted that the dealer would have done a thorough PDI but I trusted wrongly. Clearly it's the dealer's responsibility to ensure everything is right before they turn it over to you.
/ problems with new kubota bx23s #4
When I had my machine delivered, BEFORE I signed for the delivery, I made sure everything worked on the machine with no leaks no issues. Took me like 45 minutes to go over it, but I'd rather deal with them already there with the trailer, than calling them back.
Some get offended by this -- but it's my machine and more importantly it's my hard earned money...
/ problems with new kubota bx23s #5
Yep, I agree. My mistake and a valuable lesson learned. Won't happen with me again.
/ problems with new kubota bx23s #6
Here's a good one...
I bought (then got refunded) a brand new ATV a while ago, and I tried doing the same thing. Delivery driver told me I had 2 minutes to quit wasting his time. I told him, No! So I got on the trailer and was inspecting it, and he told me I couldn't look at it on the trailer that it was a liability to him. So I turned and looked at him, and said, Ok, be that way! Don't bother dropping it off, I am going to get my money back!. He said I couldn't do that and he had to drop it off. I told him no way!! I told him that if he drops it off, I will call the police for menacing and dumping. I stood behind the trailer and he was tempted to try to push me out of the way, but knew better. He finally drove off. I called the dealer and told them what occurred. Long story short, I got my money back.
Next dealer I dealt with, the delivery person was very eager for me to inspect everything, and even pointed things out that I wouldn't even know about to look at. Was very happy with the whole process.
Long story short - never accept a large value delivery while you are not there. Especially on equipment!
/ problems with new kubota bx23s #7
Couldn't agree more. What made it worse in my case is that I picked up my tractor and implements at the dealer. I guess I was impatient after waiting almost 2 months for everything to arrive. And I wanted to get everything home and in the garage before a big storm was scheduled to hit. Like I said - lesson learned. On the bright side I've become pretty good at finding and fixing leaky hydraulic fittings. And my toolbox now contains all the special tools I need to get at them.
/ problems with new kubota bx23s #8
Hydraulic leak is probably from a misaligned swing cylinder hose that got pinched. It is a FACTORY problem that has been going on for well over half a year. We have to reposition the swing cylinder rod end elbow on every BX23S that we receive.
/ problems with new kubota bx23s #9
That's what I like about this forum. A number of tractor owners can relate their questions or experiences and every now and then an expert gives us their own opinion or advice based on their professional experience. I learn something new every time I check in.
/ problems with new kubota bx23s #10
After reading your response I went and checked mine. The nut was very loose, and dripping. What position do you move the elbow to?
/ problems with new kubota bx23s #12
Thanks, I'll keep an eye on it. Mine is about 20 degrees from centerline parallel. I'll check the full swing motion of the cylinder to see how much I can tighten the elbow, if needed.
/ problems with new kubota bx23s #13
Final assembly for your tractor occurs at the dealership. That repair looks like the dealer tech kind of repair.
Id be really suspicious about the dealer assembly quality and physically check and re-torque every bolt on the wheels, loader etc. Expect to find missing bolts/nuts/cover plates, loose/untightened hydraulic fittings, etc. Once you check the bolt torque get a paint pen and mark the bolt heads at the 12 o’clock position. Its a quick way to check if something is getting loose when you do your morning pre-trip walk around.
I tightened the fitting on the swing cylinder and the leak seems to have stopped. Took a pic of hose to check the clearance and wow, its rubbing.
Ok dealer came out and replaced the hose for the swing arm. I told him about the post that says to move the angle of fitting (thanks RickB) so it don't rub and he agreed. Problem resolved. On the tape job on the seat switch, we untapped it and there was nothing wrong with the wire or switch but someone thought it was better to tape it up to keep water or what ever out and just didnt do a good job. I retaped and dont think there will be a problem with that.The seat lever I think the whole problem was the cotter pins they use on the Kubota tractors will add pic.I put the old fashion cotter pin back in. seat should be good.
Thanks all
/ problems with new kubota bx23s #18
New SC-TLB owner here. Just picked up my new BX23S last Wednesday. First day of use, after about 3 hrs, I saw hydraulic fluid spraying out of a BH flare fitting. Two of them were loose and a third hose was rubbing on the swing cylinder at full left. Tightened the fittings and moved the one hose slightly to avoid rub. Should I worry about the amount of rub I have on this hose? Second question / observation. 11/16 does not seem to be an exact fit for the flare fittings, there is a tiny bit of "slop". Is there a special wrench for these?
I think all of the kubotas are metric so try a 17 mm instead of 11/16. I love my new bx23s now that things are working right on it . I used it sat and sunday clearing trees and brush and digging out trunks hope yours works out. also looking at that hose I would get that replaced under warranty
/ problems with new kubota bx23s #20
Thanks for the info. I should have been more specific. At first, I did try metric and 17 would not fit, but 18 was obviously too big. I just now went and looked again and found that 17 "almost" fits. I can wiggle it about halfway on, but I don't want to force it. I guess the tiny slop in 11/16 will remind me not to torque the **** out of the fittings. :)
I love my new BX23S! I already have 13 hrs on it. I have been pulling scotch broom (kinda like small, short root trees, no bigger than 3" dia trunks). I live on the North Oregon Coast and my soil is sand, so the BX works great.
2015 CHEVROLET CAPRICE POLICE CAR (A66091)
2015 CHEVROLET...
2022 Mac Trailers 48ft. T/A Walking Floor Trailer (A64556)
2022 Mac Trailers...
2012 FORD F150 REGULAR CAB PICKUP TRUCK (A66091)
2012 FORD F150...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
2021 CATERPILLAR 420XE HRC BACKHOE (A65053)
2021 CATERPILLAR...
KIVEL TRAILER MOVER ATTACHMENT (A64553)
KIVEL TRAILER...
