Tool cat Jerky HST
/ Tool cat Jerky HST #1
Wildbird
Sturbridge MA
Bobcat tool cat 5600
I own a wild bird store in Massachusetts and bought a used Toolcat with highflown to move pallets of bird seed and plow snow. It has aprox 3800 hours on it and seems to run pretty good and does the Job. Other than rust the only issue I am having is the HST is very jerky. No mater where you set the throttle and or how easy you press on the pedle it creeps along very jerky. If you are moving at bout 2 miles per hour its fine but any slower trying to get a set of forks under a pallet is very difficult because it lunges forward. Any thoughts would be appreciated.
/ Tool cat Jerky HST #2
By the title I expected a recipe for dried meat snacks. :licking:
Someone will be along with more useful comments, I'm sure. And welcome to TBN! :thumbsup:
/ Tool cat Jerky HST #3
Have you put it in work mode? If not give that a try, it remaps the throttle inputs and makes slow precise movements much, much easier.
/ Tool cat Jerky HST #4
Yes, I also find WORK mode works great for slow speed control.
Thanks for the input I will try That and I will also change the hydraulic filter.
Wildbird
/ Tool cat Jerky HST #7
I am REALLY going to have to reach back in time on this one... I have a 2007 "D" 5600. Years ago I encountered a speed variability ("jerkiness") problem that made my Toolcat pretty much unusable. Work mode dampened the problem but the rig was still pretty much unusable. To cut to the chase... I turned the Power Management off on my machine and the problem went away. Ultimately, the issue was a bad RPM sensor (the sensor is mounted near the flywheel of the Kubota motor, IIRC). So... look for erratic RPM readings as you drive along while avoiding whiplash. If the RPM is going all over the place, you might have found the problem. Alternatively you can turn your Power Management function off and see what happens. (Sorry, I don't remember how to switch it off.)
/ Tool cat Jerky HST #8
Does it do it in high speed also?
/ Tool cat Jerky HST #9
I'm thinking pump and or pedal calibration. :confused3:
2016 Ford F-550 4x4 Venturo ET25KXX 2 Ton Crane Service Truck (A61573)
2016 Ford F-550...
(2) UNUSED 27X8.50-15 TIRES W/ 6 LUG RIMS (A64280)
(2) UNUSED...
211297 (A62131)
211297 (A62131)
Deere 50D (A60462)
Deere 50D (A60462)
UNUSED WOLVERINE TDB-11-66W-66" BUCKET (A64281)
UNUSED WOLVERINE...
2013 FORD F250 (A60460)
2013 FORD F250...
