eubie5
Gold Member
- Joined
- Mar 25, 2003
- Messages
- 256
- Tractor
- kubota bx2380
Ok, been looking for a new subcompact for 6+ months. Checked out the bx2380, mf1705, and the rk24, all fit with a 3rd function. Also looked at the branson 2510, but that's probably bigger than i need, but ****, the branson is a heavy built tractor. I want to run a small grapple when not using the fel. I currently have a 2002 bx1800, and it's a little tank. It does not have a loader, which i kick myself in the *** for not getting one. The 1800 has done everything I've ever asked of it. It will lose traction before it loses power. When i add weights to the front, it's like an entirely different tractor when I'm grading my gravel drive. It would do even better if i wasn't running turf tires.
My question is, would i be ok looking at dropping down to the new BX1880? It only weighs about 100lbs less than the 2380. The frame is the same, the hydraulic output is the same.
It actually has the same fel as the 2380 and 2680. All the fel specs are the same.
Just wondering if I'd be happy with the new 1880 with fel?
Anyone else have one? Are you happy with it's ability? I live on about 2.5 acres and mow the entire thing. I have a gravel drive that's about 375 feet long. It has a big hill on it, and I've never been able to grade it perfectly. I do a decent job, but i start losing traction going up hill. That's why i was looking at jumping up in size. But everything I've ever read, you really don't see a jump in tractor ability unless you jump up at least 50% in weight. The tractors I've been looking at do not meet that 50% criteria.
So, whatever i get, with a fel, and r4 tires i think I'd see a much better end result than what I'm currently using.
Ok, I'll quit rambling.
Let's hear from you guy's who bought a BX1880, or a rk19, or the branson 19hp.
Are you happy going so small, or do you regret it, and wish you'd gone bigger?
Thanks
Thanks
