Camera Security Systems???
/ Camera Security Systems??? #241
Did you ever solve this? If not, it is easily solved by downloading FLIR cloud to your computer and accessing your DVR via internet. I made the same mistake.
I did not.
Yet.
I ordered a 4K TV which is scheduled to arrive tomorrow...
:p
/ Camera Security Systems??? #242
I did not.
Yet.
:p
Ahh, well that’s a plus then. Lol
Their tech support takes forever to answer a call, but once you have them, they are good at resolving issues
/ Camera Security Systems??? #243
I did this too. I didn’t reply because I couldn’t remember how I reset it. Pretty sure I must have used the FLIR app.
/ Camera Security Systems??? #244
When I did it I was sick... thought I had screwed myself.
But, after 30 min or so of research, I was able to download the application to my Mac, open it and gain access, change the resolution and restart the NVR. Then, was back up on the tv no problem.
/ Camera Security Systems??? #245
A little snow, a full moon, a low light camera and .... presto ... near daylight at 1AM:
I didn't know you had trees where you live?
Where is that anyway?
/ Camera Security Systems??? #248
Just a small update on the Reolink Argus 2 (not to be confused with the Netgear Arlo 2).
One of my reasons for buying them was the ability to move them around.
The camera has a concave base with magnet inside, designed to fit over a metal mount that is about the size of a golf ball.
I really like the small magnetic mount. It's easy to put a camera on and take it off, even when I can just barely reach the mount. So I screwed one in to the under eave soffit on my front porch. I've one on a magnet that I put on my truck or trailer to use as a backup cam.
These look very much like the mounts for the Netgear Arlo 2.
But Reolink has been out of stock since before I got my cameras in 2018. So I finally broke down and bought a set of chinese knockoffs of the Arlo 2 mount on Amazon - https://www.amazon.com/gp/product/B073XHRQP2/ref=ppx_yo_dt_b_asin_title_o00__o00_s00?ie=UTF8&psc=1
I'm happy to write they fit perfect.
The camera has a tripod fitting, but that requires screwing on, I much prefer the magnet mount.
/ Camera Security Systems??? #249
I can't remember exactly where I left off with my contributions here and I'm a bit lazy to go back...
That said, I have installed a combination of Reolink and Dahua POE cameras hooked up to my home network. Running Blue Iris software on a dedicated PC. I very much like the Blue Iris software and how I can customize each camera, recording, triggering, alerts, etc. Between the two camera brands, I now believe the Dahua are much better than the Reolink's. Reolink's routinely loose partial signal and it appears to be a fault in their design based on info learned on ipcamtalk.com forums.
So, if you go this route... I suggest you steer clear of the Reolink's. I am not bad mouthing them but just saying they are not totally compatible with the system I have set up.
/ Camera Security Systems??? #250
Another update -
I came to realize that my "need" for cameras is far greater than my wallet wants to support.
To decently "cover" a building one usually needs at least 4 cameras, with all their infrastructure, on the corners.
I either need a lot more cameras and wiring or fewer buildings.
So I've been looking at a less expensive alternative.
In the past I've had a few Foscam PTZ.
Moderate support, changing standards, at times flaky hardware.
I bought some Netgear precursors to the Arlo - no PTZ but inexpensive, then Netgear promptly dropped support.
Now I'm playing with Wyze cams. Extremely inexpensive ($20). One son (who lives alone) has about 5 of them and uses them for monitoring his house and dog. So I bought some. I've two of their "Pan-cams" and 4 of their "V2"'s.
They are minimalist cams. Don't work with blue Iris. But I bought the 4 V2's for less than the cost of 1 of my Reolinks.
I've run 1 of the pan cams off a little $15 10AH battery pack for about a day with no problem. That plus a ziploc bag gives me most of the functionality of my Reolink but I get 4 times the "eyeballs" on the world.
Is anyone else trying these?
/edit - also they don't work with Windows or Linux, only Android or iOs
/ Camera Security Systems??? #251
i just bought an Arlo Go. i have a couple properties with a couple houses and a lot of trespassers. looking for something easy. been playing with it in my yard to get a feel for it. i am looking for camo for the camera itself and looking for non noticeable simple mounts. i do not want this thing stolen. have a camo skin coming in to start and getting a couple knuckles that i hope to add to ells that have a wood screw end and a 1/4 in thread on other. thought i could leave these in trees and move camera around. don't know where i could go with it. depends how it works out. i have another small property a couple hours away that i might want to move it to once in a while.
Again my largest concern is theft at this point
any thoughts?
i saw a camera at cabellas that used mobile phone service that also looked interesting
/ Camera Security Systems??? #252
Another update -
Not a solution for someone seeking an inexpensive solution, but is a solution for those that want better coverage of a structure like you are describing. Vivotek makes cameras that use a 360 degree fisheye lens to provide full 360 degree coverage of an area. An installation as you describe, 4 cameras on the four corners of a building, these cameras provide double coverage of all four walls and a 360 degree view surrounding the building. To have the same coverage with standard "point and shoot" type cameras, would require 12 cameras (3 cams on each corner).
The fisheye cameras are not inexpensive when compared to a standard camera, but once you consider the extra cabling and system requirements for 4 cameras versus 12 for the same coverage, the cost of fisheyes are much less expensive.
A PTZ camera requires input to point the camera at what you want to see, a fisheye sees everything all the time... Fisheye is vastly superior to PTZ unless you are spending big dollars on a PTZ that has a really nice "optical zoom" built into the lens AND a security guy to move it around so it is pointed at the guys that are robbing your place.
This is what a fisheye camera sees:
This is that same image, rendered in real time by the software into four individual views:
/ Camera Security Systems??? #253
Right. Fisheyes and dewarping of the view into multiple is a game changer for a lot of difficult areas.
/ Camera Security Systems??? #254
If you really want to spend some money on a great PTZ solution that doesn't need a security guy to point it at the action, Vivotek also has a dual camera setup where they couple their fisheye camera to a 20x optical zoom speed dome PTZ camera. The fisheye monitors the full 360 degree field of view, and when the fisheye detects motion, it will direct the PTZ to aim at the moving object and zoom in to capture the action in high detail.
/ Camera Security Systems??? #255
Amazing, but simple in concept. Use the fisheye to monitor and the PTZ to zoom in and capture the activity. I had not heard of that before.
/ Camera Security Systems??? #256
How are the fisheyes at night vision? I know there is no IR, but many cameras do very well without that. Also, how do they do with washout from motion sensor lights? You are right about not being inexpensive but in my case I am looking at 4 cameras at selected corner locations of my house and they would do what 10 standard cameras would be needed to do. Also, what software are you running to handle the multiviews?
/ Camera Security Systems??? #257
Actually, they do have fisheyes with IR.
Vivotek S Series FE9391-EV 12MP 360° Panomorph FE9391-EV B&H
I use the software that is included with the cameras, VAST2. It is included with no additional cost and has lots of nice features. The cameras do work with other software and other cameras will work with their software.
/ Camera Security Systems??? #258
$1050........ THUMP... someone call 911
/ Camera Security Systems??? #260
Those Wyze cameras looked interesting the. I read. Bunch of the reviews on Amazon...lots of concerns about it recording when turned off, connecting to servers in China, other functionality issues.
Towable Dual-Line Pipe Road Crossing Trailer (A63689)
Towable Dual-Line...
ROUND BALE HAY RING (A63291)
ROUND BALE HAY...
1999 Bell B25C 6x6 25 Ton Articulated Dump Truck (A61572)
1999 Bell B25C 6x6...
Safety Basket Forklift Attachment (A61572)
Safety Basket...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
