Rear remotes
/ Rear remotes #1
Ridge
If a person wanted to add a grapple ( me) to save money after buying a new XR4140HC could you run the front 3rd function off the rear remote by just running hoses to the front and making sure they are secure and long enough for full function?
/ Rear remotes #2
That is what I have done on my tractor, I use the tractor hydraulics going to the front of the loader for my grapple and snow blade angling.
/ Rear remotes #3
Yes, I've done the same to operate a power angle plow, hydraulic post hole auger or a thumb on my forks.
/ Rear remotes #4
A lot of people do that. It's an option that is considerably less expensive than adding a 3rd function as long as you can sacrifice the use of the rear remote and the convenience of having the control on the loader joystick.
/ Rear remotes #5
If I would have had rear remotes I probably gone that route;didn't so went with a third function and really like that set-up.I have run(temporary) hoses to the rear for a planter.
/ Rear remotes #6
I went the whole nine yards and had a WR Long third function installed. It runs the jaws - open/close on the grapple. It's handy to have the toggle on the joy stick. I'm sure I could have been satisfied with the third function coming off the rear remotes also.
/ Rear remotes #7
For those who use rear SCV: Do you have disconnects/connectors on both ends of the long hoses that connect to short hoses on the grapple, or are they directly connected to the grapple's cylinder?
I've been considering putting a poor man's grapple on my fork frame (something like "The Thumb").
How much would you expect to pay for 2 long hoses with quick connectors on both ends?
How much would you expect to pay for a couple short stub hoses with quick connectors from the grapple ( or "The Thumb") that I would connect into the long hoses?
Or is there a better way?
/ Rear remotes #8
I ran the lines from my rear valve up under the cab to the loader frame, following the factory lines along the loader boom then to my quick connector mounted on the loader torque tube. The fancy 9500 series quick connector was my most expensive (about $120) piece and I had that from a previous purchase on sale. A 3/8" 120" jic ended hose will be $27 to $28 from Surplus Center.
A fairly easy way to figure out the length lines that you will need is to route a garden hose thru were you would run the hoses mark it then pull it out to measure.
As far as the quick connects they can run from $20 a set on up,
I have 3 remotes, the top one is going to my hydraulic top link, the middle one to the back blade and the lower one with the right angle fittings is going to the front. Depending on what's going on I can and do move them around.
lines coming up along the loader frame,
along the boom arm,
to the quick connectors, this fancy one is not needed but is nice, any of the bracketed ones would work.
/ Rear remotes #10
You want to have disconnects at the grapple so you can leave the lines on the tractor otherwise it would be a major pain to swap the grapple with other implements if you had 20' hoses attached to them. The long hoses stay with the tractor, short hoses from tractor to grapple connecting on the loader frame up front.
/ Rear remotes #11
Coby, That's what I did. I bought 1/2" ready made hoses at my local TSC store (3500 PSI) and also the quick connect fittings which I have at each end of the hoses. I believe my hoses were 14'. I bought some 90 degree fittings and ran the hoses under the tractor to the front zip tying every foot or so. I bought various length shorter hoses for each attachment. Some were 4' some 6' depending on attachment. Cost for everything was around $200. Now I can use the Thumb or Hyd PH auger on the front.
/ Rear remotes #12
I have been thinking on how to do rear remotes and 3rd function..
I think I have sort of settled on similar to what NYLou did above, with additional quick connects on loader post so I can take loader off if I want and not have to mess with the long hoses from the rear. I'm over thinking it, but will just do it when the time comes.. likely influenced by price and availability of parts needed..
/ Rear remotes #13
I went with the WR long third function kit for my XR4140H (Electric over hydraulic vslves). Works great with thumb switch on front controller and with longer hoses that stay on tractor when I disconnect grapple. Expensive but I installed myself without having much hydraulic system experience!
/ Rear remotes #14
If you install the wr long 3rd function, you can take it off the mounting plate and bend the plate in a vice and remount the hydraulic valve so that it tucks in underneath enough to still use the step on that side without kicking the valve. If you just mount it, it interferes with the step.
/ Rear remotes #15
one of the issues with the WR Long kit though from what I've read is it's not recommended to use for anything that's going to be in action very long like a PHD or broom. Says it right in the information on the order, at least if you look it up on everything attachments site it does. I've been drooling over the limbninja front mount hydraulic bush hogs, and I don't think it would be suitable to run it on the WR Long kit, but I would expect coming from the rear remotes it probably would be fine.
of course I don't have rear remotes either, so there's that....:laughing:
/ Rear remotes #16
Don't most hydraulic PHD's, Brooms, Rotary Cutters require high flow?
/ Rear remotes #17
Papa i ran across a LS dealer site that had a u tube of how to install the rear remotes, i did a google didn't find it but think it was a northern dealer. Dummy me i didn't save the site. My dealer installed remotes on my tractor and only charged me his cost with no labor.
/ Rear remotes #18
I will be using my rear remote to operate my jaws of my root grapple , found the 1/2 inch X 10 ft hydraulic hose 3500# for $33.22 each on e bay, I ordered the ISO 5675 3 males and one female hyd couplers with cap protectors from Amazon for $32.
I use a hydraulic cylender for my middle hook up so i can adjust my Disk, Tiller, 6 ft finish mower and planter without getting off the tractor. I will cap the ends of the hyd cylender or root grapple hoses and rig up some way to hold them out of the way when not in use. Everything is on order and will be here by next week.
/ Rear remotes #19
Well everything is installed and the root grapple is a awesome tool for my tractor.
I bought a MTL 48 inch grapple for $890 and was surprised at quality and its rugged build , this is a cheap in price grapple but not in quality i am impressed after using it.
If you are thinking about using your rear remotes to operate the grapple i would like to add that if i had it to do again i would use 3/8x 15 ft hoses instead of 1/2 inch and the 3/8 can be bought on e bay at a reasonable price at approximately 1/2 of the cost at my local hydraulic shop.
I dont see any problem with using the rear remote lever for opening and closing the grapple.
This is the best $1000 i have spent on equipment for my tractor .
/ Rear remotes #20
Very good advice, that's what I did! Every thing works fine with 3/8" hose. Much easier to route and much cheaper also. I put 2 disconnects on loader arm also.
Not a big deal for me to operate front hydraulics with 3 point lever.
2022 EZ-GO ELITE...
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
2007 DRAGON 130BBL VAC TRAILER (A60736)
2007 DRAGON 130BBL...
2023 BOBCAT T770 SKID STEER (A62129)
2023 BOBCAT T770...
2019 JOHN DEERE 333G SKID STEER (A64279)
2019 JOHN DEERE...
2018 CATERPILLAR TL1055D TELESCOPIC FORKLIFT (A62129)
2018 CATERPILLAR...
