What else do you do with forks besides lift pallets?
   / What else do you do with forks besides lift pallets? #241
I also easily move and store my other BX implements.
   / What else do you do with forks besides lift pallets? #242
I may have already posted this. If so, sorry.
My Chicken Coop:
And my pole barn deer shooting house, it's nominally 6'x8':
Getting ready to set it. You can see I already have the Elevators (4x4 post attachments) on the shooting house and the 4x4x10' posts ready to go:
And it's up:
   / What else do you do with forks besides lift pallets? #243
Used my forks twice today... loading garbage cans in my pick up and blackberries on the burn pile. Seems I am better off leaving them on and swapping to my bucket when needed.
   / What else do you do with forks besides lift pallets? #244
Which length forks do most people prefer, 42" or 48"? This would be for a variety of uses on a 70HP utility tractor that would range from picking up rocks to occasionally using on a 2000 lb pallet. The fork frame I have is rated at 3800 lbs.
This question comes up because it's hard to keep my 48" forks straight when picking up a pallet of fertilizer and I rip some bags. I only do it a few times a year and the rest of the time is rocks, trees, etc. No pallets.
Would 42" forks make life easier or should I just learn the 48" forks?
I would say 42" forks as they will not stick out past the pallet...
Aaron Z
   / What else do you do with forks besides lift pallets? #245
Aaron Z
I would agree. Unless you you have applications that require 48in I would not go that long. I work in tight quarters and total tractor length is a factor.
   / What else do you do with forks besides lift pallets? #246
Aaron Z
I will be getting 48" because I want the longer ones for brush piles, logs, and the like. The negative is that they will go through a pallet and into the next if you are not careful but I do very little pallet work so it isn't a big deal for me.
   / What else do you do with forks besides lift pallets? #247
What an interesting thread to read through! Clearly my forks are under utilized.
I mostly use mine for brush and trees, but have moved a refrigerator to a neighbor's garage and set out a manger scene for another neighbor. I need (want) to load a 55g drum onto and off my truck for gasoline filling. I have one of those barrel grabbers that use the weight of the barrel to keep pressure on the top lip, but I just don't trust them. I may just tie the barrel onto a pallet for lifting.
   / What else do you do with forks besides lift pallets? #248
Raise up the front of the tractor to look for a hydraulic leak.
Hauled an old mattress away that would have been a hassle to carry by hand.
   / What else do you do with forks besides lift pallets? #250
Now I've got to go read the whole thread.
SAMSUNG SMART REFRIGERATOR (A54757)
SAMSUNG SMART...
2014 PETERBILT 388 (A55745)
2014 PETERBILT 388...
MISC LOT (A55745)
MISC LOT (A55745)
1997 CATERPILLAR 322BL EXCAVATOR (A52707)
1997 CATERPILLAR...
16ft Gooseneck Livestock Trailer (A54865)
16ft Gooseneck...
