04 john deere charging bafflement
/ 04 john deere charging bafflement
It could be that the alternator wire was rubbing the frame ...
/ 04 john deere charging bafflement #22
Although you found the cause of your lack of charging, my friend just came up with a WSM.
For the future, here is the charging circuit.
The tractors wiring has about 8 diodes including V6
The safety relay K3 and its diode V6 is to protect the regulator from reverse battery polarity.
The WSM also comments:
Diodes usually fail in the open position but can fail shorted. If any problems in charging circuit check both V6 and V8 diodes.
I expect the relay would be the same as most automotive headlight relays.
I am surprised the relay was the issue as it is just a battery voltage sensing circuit carrying no real power that would burn the contacts.
Here is the list of relays:
K1 - Start Relay (SE1, W1)
K2 - Fuel Relay (SE2, W1)
K3 - Safety Relay 1 (SE3, W1)
K4 - Safety Relay 2 (SE3, W1)
K5 - Flasher (SE4, W1)
Do you need more help?
Dave m7040
Hi Dave, just a quick question. What is the purpose of the K4 safety relay? I swapped the K4 to the K3 connecror temporarily to verify that was my charging problem. As soon as I did that I was reading 14 V plus at the battery with the tractor running. PS, thanks for posting the wiring schematic.
/ 04 john deere charging bafflement #23
K4 relay is linked to seat switch to verify operator on tractor or fell off.
Dave M7040
