04 john deere charging bafflement
   / 04 john deere charging bafflement
It could be that the alternator wire was rubbing the frame ...
   / 04 john deere charging bafflement #22
Although you found the cause of your lack of charging, my friend just came up with a WSM.
For the future, here is the charging circuit.
The tractors wiring has about 8 diodes including V6
The safety relay K3 and its diode V6 is to protect the regulator from reverse battery polarity.
The WSM also comments:
Diodes usually fail in the open position but can fail shorted. If any problems in charging circuit check both V6 and V8 diodes.
I expect the relay would be the same as most automotive headlight relays.
I am surprised the relay was the issue as it is just a battery voltage sensing circuit carrying no real power that would burn the contacts.
Here is the list of relays:
K1 - Start Relay (SE1, W1)
K2 - Fuel Relay (SE2, W1)
K3 - Safety Relay 1 (SE3, W1)
K4 - Safety Relay 2 (SE3, W1)
K5 - Flasher (SE4, W1)
Do you need more help?
Dave m7040
Hi Dave, just a quick question. What is the purpose of the K4 safety relay? I swapped the K4 to the K3 connecror temporarily to verify that was my charging problem. As soon as I did that I was reading 14 V plus at the battery with the tractor running. PS, thanks for posting the wiring schematic.
   / 04 john deere charging bafflement #23
K4 relay is linked to seat switch to verify operator on tractor or fell off.
Dave M7040
2019 TOYOTA 8FGCU25 PROPANE FORKLIFT (A52141)
2019 TOYOTA...
2007 JLG SkyTrak 10042 10,000lb 4x4 Rough Terrain Telehandler (A50322)
2007 JLG SkyTrak...
2025 Future Stump Grinder Mini Skid Steer Attachment (A50322)
2025 Future Stump...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
2010 Toyota Camry Sedan (A50324)
2010 Toyota Camry...
2011 Chevrolet Impala Sedan (A51694)
2011 Chevrolet...
