B3000/B3030 LED Headlight BUlb ?
   / B3000/B3030 LED Headlight BUlb ? #11
Nice job on the lights. I have LED flood/spot lights on my hard top too but I don't always have it on my tractor. It's too tall to fit through my barn door so it comes off for the winter.
***NEWSFLASH***
I went to my B3000 to pull the existing OEM bulb(s) out to measure them to make sure I didn't order an LED replacement that was too long to fit into the headlight housing.
The bulb(s) that are currently in the B3000 are a #1073. A single contact, bayonet type bulb, 12V 23Watt.
It doesn't have that weird round flange around the bottom of it. It looks like a "normal" bulb that should be more easily replaced than if I had one of the weird motorcycle bulbs.
It also explains why I don't have a high beam and low beam selection on the tractor. It only has one filament.
So I am off to google/search for a LED replacement.
I'll let you know what I find.
Thanks.
   / B3000/B3030 LED Headlight BUlb ? #13
I am stuck not being able to get to my camp and my tractor for a while so I can't pull my bulb to compare. But from the brief searching I've done, the 1073 bulb appears to be the same configuration as an automotive 1156 bulb.
From Messick's parts site this is the bulb from the 2650
From the same site this is the bulb from the B3000
Don't know if this will help you in your search. Hope it does.
Thanks GRTkub.
That is a picture of pretty much, what I have.
I have done a search for bulb #1073 LED Replacement and gotten some results back.
I believe the LED equivalent of the 1073, is an 1156, but not positive.... yet...….
Now I need to research to see what others have used successfully and if they liked the results.
Regards.
   / B3000/B3030 LED Headlight BUlb ? #15
While looking for some other information on this forum I came across a link to this thread on the other Kubota forum.
K7324 Alternator Kit Sourcing? - OrangeTractorTalks - Everything Kubota
In it a B2650 owner expresses his satisfaction with these replacement headlight bulbs.
https://www.amazon.com/gp/product/B017QR53NS/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
RJ -- Why didn't you replace your headlights? They appear to be the same as my 2650 (I couldn't find where it specifically calls them "Headlight Bulb"). If so, I am really pleased with the LED bulbs I put in mine, they are substantially brighter than the stock incandescents and throw a nice, crisp light over a wide area and stay way cooler. $15 from Amazon: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I just purchased a pair of those bulbs.
They were delivered last night so I have not had a chance to install them on the tractor yet.
   / B3000/B3030 LED Headlight BUlb ? #17
Awesome. Please let me know how they work for you.
Yes. The bulbs fit and work with no problems at all. Be aware that they are only one intensity. No high and low beam. They are much brighter than the OEM bulbs.
Tube Broom 8, 5/8 x 58 Poly 26" (A59076)
Tube Broom 8, 5/8...
2007 Jeep Wrangler Rubicon, VIN # 1J4GA39197L104496 (A57453)
2007 Jeep Wrangler...
21001 (A59231)
21001 (A59231)
2007 Ford King Ranch F-150 (A57148)
2007 Ford King...
Giyi Land Leveler (A57149)
Giyi Land Leveler...
2010 GLOBAL TRI AXLE HAUL TRAILER (A58216)
2010 GLOBAL TRI...
