Beet juice
/ Beet juice #1
1930
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
Stupid question but is it really beet juice as in the vegetable?
I told my dealer yesterday that I wanted tractor weights added to the wheels, he told me that instead they would fill the tires with water.
I told him no way I don't want water or windshield washer fluid in my tires.
If anything I wanted beet juice cuz I've read online that was the proper thing to fill the tires with.
after thinking about it for a couple of minutes I decided I just wanted weights so that if I ever punctured a tire I wouldn't lose whatever was inside of the rim.
So what exactly is beet juice
/ Beet juice #2
Beet Juice is a byproduct of turning sugar beets into granulated sugar. Sugar beets are grown in many areas of Michigan. Beet juice or beet juice blends are heavier per gallon than plain water or windshield washer fluid and will not freeze at temperatures normally encountered in winter. Beet juice is also considered by many to be non-corrosive when compared to calcium chloride tire ballast.
/ Beet juice
Is it thick like syrup or is it more watery what's the consistency?
/ Beet juice #4
The biggest reason we use beet juice (commercial name is "Rimguard") up here is the low freezing point. It won't freeze solid at -30 to -40 F that we see here in winter. The fact that it is more dense (heavier) than water per gallon is just a side benefit.
When I lived in AZ (born and raised N. of Phoenix), we used only straight water for tire ballast. It never got cold enough for a long enough duration to freeze the entire volume of water in the tires, so it wasn't a problem.
Being as how you are in Florida, I don't see the reason to use Rimguard down there. Straight water would be just fine, it's cheap, plentiful, and easy to replace if needed.
/ Beet juice #5
Rimguard is also environmentally friendly. Whereas some of the other compounds put in tires is not. So if you were to puncture a tire you not only have to deal with the fluid loss, but now you have a contamination issue to clean up.
Around these parts (Northern Indiana) they use some formulation of beet juice as an anti-icing agent when we know snow and ice is on the way. It is more expensive than salt, but works better and does not contribute to cars rusting.
Generally fluids in the tire are cheaper per pound than wheel weights.
Where you are I would consider water. If it gets too cold for a brief period during winter you can always remove the water. Since it is cheap you can easily replace it in the spring. Tools for filling your own tires are available and fairly cheap.
Up here in the great white north as mentioned we need something that will not freeze until at least -20F or so.
/ Beet juice
I recently had to replace a tire on my B series Kubota, it was filled with water and the rim had all but rotted out.
I'm sure that it had been in there a long time
/ Beet juice #7
More watery than syrupy...
Regardless of what fluid you are using, I would recommend installing tubes first. I've heard of folks tires spinning on the rim under a heavy draft load and a tube would provide a larger friction surface across the well as opposed to just the bead seat area. Tubes would also limit the possibility of contact between the metal rim and ballast fluid.
/ Beet juice #8
My first tractor had calcium chloride - salt water - in the rear tires. It worked fine for about ten years. Then it became a REAL PITA. I had to replace the valve stems at least twice annually.
I'm pretty sure beet juice is about the heaviest liquid that you can have put in your tires. I've had it in mine, now, for ten years. No problems.
Whatever you finally decide - have some anti-corrosion product added also. No need to have ANY corrosion problems when so many good products are readily available.
/ Beet juice #9
Beet juice does not really make any sense in Florida.
Yes... it is the heaviest liquid for tires that you can use, but it is also the most expensive, and messy if you should have a leak.
It may be the best in cold climates, but you are in Florida.
CaCl also is heavier than water, but will destroy your rims over time.
In Florida: Stick with water!
In most places it is basically free.
/ Beet juice #10
Even if you are in warmer climates, I would go with beet juice. It is heavy, pure and simple. If you are in need of ballast, you will need all you can get. Water weighs 8.34lbs/gal putting my tires with 55 gallon capacity at 458.7lbs per tire. If I fill (and I did) the tires with beet juice, weighing in at about 10lbs/gal, they weigh 550lbs per tire. So about 100lbs more per tire, and there are two the last time I checked. Every bit adds up. Yes, it is more expensive than water or windshield washer fluid, but remember the reason you are considering it, weight.
/ Beet juice #11
If I lived in FL, I would use WW fluid rated at 0*. It will never freeze and it is cheap. I live in northern MI and used -20* WW fluid this year in my old JD patched tires. I did it myself for a total cost of under $75. Seemed dumb to spend $300 on tires that may leak again.
My new tractor, will have beet juice. Over the life of a new $35k tractor, saving a $300 also seems dumb.
/ Beet juice #12
Why is it that you dont want water?
/ Beet juice #13
You might want to call around and see if Rimguard is even available in your area. It's only sold through a dealer network, and if there is not enough demand in your warm area you may have to go some distance to get the product.
Also, there is no DIY installation available. You have to use a dealer to purchase and install, at least here. They charge for the product, installation fee and a service charge by the mile to get to the location.
Then another consideration is if you have to travel to get the tires filled, what will you do if you have tire problems? You bust a tire and it leaks out, then your tractor is heavy on one side and not the other. Got to go find the dealer and start over! I'd use water. Just fill it up to the very top of the wheel. Then the entire wheel is under water and rust is almost nonexistent.
/ Beet juice #14
Fill with water and add a glycol based rust inhibitor that is environmentally safe
You could fill your tires for less than $100. If you aren't worried about rust then you add weight for free
/ Beet juice #15
Running water in the tires is very common. Most people mix it with an anti-freeze or anti-corrosion agent. Tire shops in the southern climates usually use a water-methanol mix. They usually charge about $50 per tire for that. In your climate you could simply dump some windshield washer fluid concentrate in the water to provide some corrosion resistance. Beet juice is great, but it is also fairly expensive.
I run water with a few gallons of RV antifreeze mixed in. The tires I put on my Ford last year hold about 50 gallons each. I put 12 gallons of RV antifreeze in each tire at a cost of about $30 total. It is a propylene glycol mix that is non-toxic. I could see no indication of freezing when it got down to about 5 degrees a few weeks ago. If I puncture a tire it will not be any major expense to refill it.
/ Beet juice #16
I live in FL and just use water straight from my well.
The way I look at it, plain water is the easiest to deal with should I need to repair a flat.
I also figure if the old timers could get 10 or more years out of wheels when using salt water, I should get at least that although will probably get more.
I'll have to report back on the wheel condition if I ever need to take a tire off.
/ Beet juice #17
Beet juice weighs about 12 lbs/gallon. It is better IF you do get a puncture in a tire because it won't kill the grass/crops under it.
/ Beet juice #19
Get rimguard.Keep up the work on your post count.
/ Beet juice #20
From the Brandon/Ocala area I think it likely that the OP may need to drive nearly to Tennessee to find a dealer who installs Rimguard/beet juice.
Maybe 600 miles?
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
2008 Kenworth T300 Water Truck, VIN # 2NKMLN9X48M216520 (A61165)
2008 Kenworth T300...
2023 Stearling Trailer (A60352)
2023 Stearling...
UNUSED IRANCH MINI HYD THUMB (A62131)
UNUSED IRANCH MINI...
UNUSED WOLVERINE LL-12-78W 78" LAND LEVER (A62131)
UNUSED WOLVERINE...
2006 GODWIN GHP45KW-RC 45 KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
