   / Share Pics of People Hauling or Towing Something Wrong #9,481
   / Share Pics of People Hauling or Towing Something Wrong #9,482
I was convinced until it got to the part with the zip tie.
   / Share Pics of People Hauling or Towing Something Wrong #9,483
I admit my vision isn't very good, but i could only see the zip ties on that tag ends of the chains, as in just holding the slack ends, but i could have missed something. Now the rest of the setup wouldn't be the way i'd tie down that tractor.
   / Share Pics of People Hauling or Towing Something Wrong #9,484
Agreed, the zip ties have no pressure on them but the chains are hooked wrong.
   / Share Pics of People Hauling or Towing Something Wrong #9,486
We use zip ties sometimes to secure extra chain or strap, but I have little tolerance for folks that are that careless about securing a load. Hope it was in jest.
I think the rules are enforced differently in different areas, but it is my understanding that a tractor would need a minimum of 4 independent tie-downs, 2 pulling forward, two pulling back.
   / Share Pics of People Hauling or Towing Something Wrong #9,488
Full disclosure... This was me today picking up my new Husqvarna tractor! 20190311_171440.jpeg20190311_175813.jpeg
   / Share Pics of People Hauling or Towing Something Wrong #9,489
depends on the weight. 10000+ needs 4 independent tie downs, under 10000 only two are needed to be legal. i will see if i can find the section in the fmsca book
   / Share Pics of People Hauling or Towing Something Wrong #9,490
NICE trailer. Too bad that he's going to lose that JD.
Only if he tries to move the trailer. To me it seems there is zero backwards hold and almost no foward shift hold. That's at base. Each implement is not tied separately.
Total screw up that puts everyone in danger.
   / Share Pics of People Hauling or Towing Something Wrong #9,491
The front chain is zip tied to the d ring.
   / Share Pics of People Hauling or Towing Something Wrong #9,492
None of the chain or binder hooks are hooked to the trailer they are all just tie wrapped to the trailer.
It has to be a put on!!!!!
I think they had to close the binders before putting the tie wraps on.
   / Share Pics of People Hauling or Towing Something Wrong #9,493
The side chain is hooked to the front chain, The loose end is zip tied to the D ring.
   / Share Pics of People Hauling or Towing Something Wrong #9,494
Left rear binder is hooked to the D ring, right rear binder is hooked to the trailer frame.
Agreed, they are not hooked properly but they are hooked.
   / Share Pics of People Hauling or Towing Something Wrong #9,495
This is the only front hook point. Not that the back hook job is much better. Maybe they remembered to set the parking brake.IMG_1718.JPG
   / Share Pics of People Hauling or Towing Something Wrong #9,497
Rental tractor, rental trailer, in front of an rental store..........guessing this might have been how this setup was returned?
   / Share Pics of People Hauling or Towing Something Wrong #9,499
But I am sure you had the parking brake set. :D
Exactly! One strap on each end, use the excess strap to "tie down" the other side of that end... Call it good.
2015 CASE 621F WHEEL LOADER (A58214)
2015 CASE 621F...
KUBOTA SVL97-2 SKID STEER (A60429)
KUBOTA SVL97-2...
2014 Forest River Rockwood Premier 2317G S/A Pop Up Trailer (A59231)
2014 Forest River...
2017 JOHN DEERE 310SL BACKHOE (A60429)
2017 JOHN DEERE...
John Deere 6195R (A60462)
John Deere 6195R...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
