Snow snow blower for pasture
/ snow blower for pasture #1
DianneInVA
Fosston, MN
Kubota L3301
I have an L01 and have to take hay out to the pasture. This winter has so much drifting. Clearing with the FEL just makes it worse. Any advice about the PTO mounted snow blower? Thinking this might be a good counter-weight, as the tractor does seem kind of "narrow" with a bale on the spear. (Northern Minnesota)
/ snow blower for pasture #2
Yep, it will work great.
There are even kits you can add to replace the skids with wheels to raise it up even higher so you aren't chucking gravel and debris.
/ snow blower for pasture #3
Should be a piece of cake. Probably not many rocks, roots, limbs, stobs etc out in the field.
/ snow blower for pasture #4
I used our 7 ft ARPS when we had cows over the winter. I laid down the feed in the cleared area. Our pastures a re clear of tree stumps and I can see the rocks.
/ snow blower for pasture #5
I have used our 7' Loftness to clear a path through the pasture so the pygmy goats could walk around and not be stuck in the barn till the snow melts.
Aaron Z
/ snow blower for pasture #6
I also live in MN and feel your pain with the winter we've had this year. I do exactly what your questioning. I have to get a round bale out to the horses every few weeks and I keep a path cleared to the bale ring with a 6 ft 3pt blower. The only issue I've had has been with the frozen horse pooh. The blower chops it up and throws it but makes a heck of a noise and it shoots the frozen chunks a long ways so just be mindful of where the chute is aimed. Works pretty good though.
/ snow blower for pasture #7
Set the skid shoes high or carry it slightly off the ground. I clear barn yard in the winter. Frozen manure either goes through it like rocks or jams it up.
(APPROX. 60) UNUSED MISC SIZE RATCHET STRAPS (A62130)
(APPROX. 60)...
Clark Forklift (A64047)
Clark Forklift...
New/Unused Landhonor Gas Powered Water Pump (A61166)
New/Unused...
2012 Toyota Camry Sedan (A61569)
2012 Toyota Camry...
2014 Chevrolet Caprice Sedan (A61569)
2014 Chevrolet...
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
