Pressure Washer Pump Replacement
/ Pressure Washer Pump Replacement #1
chim
Elite Member
Lancaster County, PA
Kubota L4240, Ford 1210
Pump is a Simpson 3000 PSI with Honda vertical shaft engine. The engine has always run beautifully, but the pump is kaput. I'm looking for some guidance on a replacement pump. Anything in particular I should look for? Not asking for a specific replacement, but rather features that would be best to have. I'm assuming a brass body pump? Some are advertised with a brass body and it appears some have a brass-colored die cast body to imitate brass. Pressure or temperature relief? Etc........... Thanks
/ Pressure Washer Pump Replacement #2
Look up Water Cannon, call them they can help you, been buying parts from them many years.
/ Pressure Washer Pump Replacement #3
Thanks for the Water Cannon link. They have some great prices on horizontal pumps. Not sure about the vertical pumps - those are certainly pricey. I'm assuming that vertical pumps are better than horizontal pumps?
/ Pressure Washer Pump Replacement #4
This pamphlet may be helpful
http://www.catpumps.com/products/pdfs/993320E_CAT_Pump_Catalog_LoR.pdf
/ Pressure Washer Pump Replacement #5
I thought my pump was shot but found that the spring loaded pressure let off was stuck open. I can’t remember the names but it took me less than 5 minutes to fix with YouTube help. Just a thought.
Good luck
Thanks for the replies
/ Pressure Washer Pump Replacement #7
Northern Tool is where I got mine. Read up on a few specs, made some measurements, bolted right up, worked five, priced right. I keep RV antifreeze in mine in the winter now.
SCAN TO RECEIVE TEXT UPDATES (A64280)
SCAN TO RECEIVE...
2017 Ford F-250 4x4 Crew Cab Medical Service Truck (A61573)
2017 Ford F-250...
Sakai SW354 (A60462)
2014 INTERNATIONAL DURASTAR 4300 26FT NON CDL BOX TRUCK (A59911)
2014 INTERNATIONAL...
2011 Cadillac Escalade AWD Crew Cab Pickup Truck (A61573)
2011 Cadillac...
2017 Case CX145D (A60462)
2017 Case CX145D...
