Do fires extinguishers need to be shaken to prevent settling?
/ Do fires extinguishers need to be shaken to prevent settling? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
Not sure where I read it but someone wrote that fire extinguishers need to be turned upside down every now and then and shaken to prevent settling. That implies they may not work right if they sit too long and the material does settle out. Not good.Does anyone know anything about this?
I've got some that are 10 years old but still fully charged and I'm not sure what to do.
/ Do fires extinguishers need to be shaken to prevent settling? #2
Some manufactures recommend shaking dry chemical ones periodically. I can't see how it would do any harm to do it so why not do it?
This is a cut and paste from an extinguisher site.:
Fire extinguishers expire and they do this for a few different reasons. One common way is that, over time, the seal on the neck will weaken and allow compressed gas to escape. Extinguishers that have lost much of their pressure will not operate. Pressure within an extinguisher can be conveniently checked through a pressure gauge. “ABC” class extinguishers (ammonium phosphate) have the tendency to fail due to solidification of the chemical in the canister base. Homeowners and inspectors can delay this process by periodically shaking the extinguisher. Expensive extinguishers that have expired, especially those designed for commercial use, can be refilled and resealed by companies who specialize in this service. Inexpensive models are disposable.
/ Do fires extinguishers need to be shaken to prevent settling? #3
In a one word answer YES. I do mine when we go on and off DST
/ Do fires extinguishers need to be shaken to prevent settling? #4
I have always made a habit of turning ours upside down every fall and giving the bottom a few smacks with a rubber mallet to be sure the dry chemical powder inside the devices does not get caked.
/ Do fires extinguishers need to be shaken to prevent settling? #5
Yes, it is part of the annual inspection procedure. Turn it upside down and tap it with a rubber mallet if needed to loosen the powder. Gently shake or rotate the extinguisher. You can tell when the powder is loose. The other is just a visual inspection of the parts and pressure and make sure it is clean. If it has a hose make sure it is clear. The hose should unscrew from the valve and you can blow through it to verify nothing got in and made a nest. If you are required to have an annual inspection you also get a new tag showing the date inspected. In the industry this was known as the annual "rag and tag".
NFPA Standard 10 also requires every 6 years the extinguisher is discharged and refilled. Every 12 years the cylinder is required to be hydrotested. A fire extinguisher company should not refill an extinguisher out of hydrostatic date. Only the expensive metal valve body extinguishers would get tested. If the extinguisher has a plastic valve body it is pretty much disposable. You can replace it cheaper than the cost of a test and refill. Some cannot even be refilled if the nozzle is built into the valve body. The hose to charge the extinguisher with nitrogen screws in where the hose or nozzle screws in.
/ Do fires extinguishers need to be shaken to prevent settling? #6
The fire extinguisher company I use told me to turn it upside down and tap it with a rubber mallet once a month, if it makes you feel good. It isn't really necessary to do.
They said when the extinguisher was placed back on the wall hook, it would settle back down in short order. The main thing was to use a 5 or 10 pound high quality refillable extinguisher, keep it charged and the hose cleared of spider webs and bee nests, and never depend on the little cheapies sold in big-box stores.
/ Do fires extinguishers need to be shaken to prevent settling? #7
I owned and operated a fire extinguisher service for years. The only time that I took a rubber mallet to a fire extinguisher was if it was mounted, in an upright position, on a piece of moving equipment. Vibration is the only reason that the chemical powder will pack on a charged fire extinguisher.
. . . NFPA Standard 10 also requires every 6 years the extinguisher is discharged and refilled. Every 12 years the cylinder is required to be hydrotested. A fire extinguisher company should not refill an extinguisher out of hydrostatic date. Only the expensive metal valve body extinguishers would get tested. If the extinguisher has a plastic valve body it is pretty much disposable. You can replace it cheaper than the cost of a test and refill. Some cannot even be refilled if the nozzle is built into the valve body. The hose to charge the extinguisher with nitrogen screws in where the hose or nozzle screws in.
Randy's giving some solid advice. But, I would add that if the extinguisher has a plastic valve, you were a fool to buy it in the first place. Go get a real extinguisher. Plastic is fine for sandwich bags and TupperWare, but not fire extinguishers. :D
As far as a recommendation for a really good extinguisher: Amerex is the best, Badger is second and Ansul is not bad. Buckeye is a distant fourth. Anything else is pretty much JUNK!
JMHO
I have metal tipped quality extinguishers but they have set for 10 years. Will tapping be OK or replace them?
/ Do fires extinguishers need to be shaken to prevent settling? #9
If yours are serviceable, they need to be done. contact your local extinguisher company.
Six-Year Maintenance
Every 6 years, stored pressure fire extinguishers that require a 12-year hydrostatic test (e.g. dry chemical extinguishers) must be emptied and proper maintenance procedures performed [see NFPA10(98), Sec. 4-4.3]. The exception to this rule is nonrechargeable extinguishers, which are required to be removed from service 12 years from the date of manufacture. Again, this maintenance must be performed by an approved extinguisher servicing company.
Hydrostatic testing At certain intervals, fire extinguishers are required to be pressure tested using water or some other noncompressible fluid to help prevent unwanted failure or rupture of the cylinder [see NFPA 10(98), Chapter 5]. This is called hydrostatic testing and includes both an internal and external examination of the cylinder. Because this testing requires special training and equipment, it needs to be performed by an approved extinguisher servicing company.
Hydrostatic testing intervals for fire extinguishers are outlined in NFPA 10(98), Sec. 5-2 and Table 5-
2. Test intervals for some of the most commonly found extinguishers are as follows:
Pressurized water, carbon dioxide and wet chemical extinguishers every 5 years
Dry chemical extinguishers every 12 years
As mentioned earlier, the exception to the rule
for hydrostatic testing is nonrechargeable
stored pressure extinguishers (e.g. dry chemical extinguish
ers), which are required to be removed from service 12 years from the date of manufacture.
/ Do fires extinguishers need to be shaken to prevent settling? #10
Turning an extinguisher upside down and whooping on it with a rubber mallet won't hurt anything. :D
A good, high quality extinguisher that is 10 years old is most likely just fine. I say "most likely" because there is a remote possibility that the gauge could be wrong. (but that's rare. failure rate on gauges is probably less than 1%) But that's what the 6-year Maintenance is for. The fire extinguisher tech discharges the unit, verifying that it works as it should, and then recharges it.
A good, reputable fire extinguisher company should do a 12-year Hydro-Test and recharge for about half of what a new extinguisher would cost. So, no, I would not replace them. If you don't have complete confidence in them, have them serviced.
/ Do fires extinguishers need to be shaken to prevent settling? #11
Just got off the Amerex site, where I read myth #33. In a nutshell, the good people at Amerex believe you don't have to turn a pressurized fire extinguisher upside down, nor do they recommend it (and they're distasteful of the idea of whacking a fire extinguisher with something too). I particularly like the logic behind the remark about a what to do with a wheeled unit. While I understand this was written in 2013, I can't imagine a well respected brand such as Amerex would keep this info around if it was outdated. Here's a link. I don't know how to hyperlink, so you'll have to copy and paste it into your URL dialogue box if you'd like to read it yourself.
https://www.amerex-fire.com/upl/dow...-with-a-rubber-mallet-to-fluff-the-chemic.pdf
/ Do fires extinguishers need to be shaken to prevent settling? #12
We do monthly inspections of our extinguishers, and have an annual external inspection/evaluation/recharge done by a certified fire extinguisher company. Not that I plan to use them, but it makes our insurance company and VOSHA happy.
/ Do fires extinguishers need to be shaken to prevent settling? #13
I worked for a company with a fire division. All they did for recertification of dry extinguishers was inspect them, i guess for corrosion, discharge them, make sure the powder wasn't packed together and re-pressurize them. Quite the racket!
/ Do fires extinguishers need to be shaken to prevent settling? #14
We get six monthly inspections on fire equipment at work and at a training session we were told as long as the gauge is in the green it is OK and there is no need to shake or hit the base then when they come out for theinspection they hit the base with a rubber mallet :confused:
/ Do fires extinguishers need to be shaken to prevent settling? #15
We would inspect, turn upside down and beat with a rubber mallet to make sure the powder was loose. We would remove the hose to make sure it was clear, reinstall, check the gauge or weigh the co2 cartridge if applicable. Every so often they would be emptied and hydro-tested.
/ Do fires extinguishers need to be shaken to prevent settling? #16
We would inspect, turn upside down and beat with a rubber mallet to make sure the powder was loose. We would remove the hose to make sure it was clear, reinstall, check the gauge or weigh the co2 cartridge if applicable. Every so often they would be emptied and hydro-tested.[/QUOTE
Worked at a factory where a few extinguishers would fail because the powder was packed to tight. (Never used one personally that didn't work properly)
We did the exact process Doofy mentioned every year beside the monthly blessing.
I think though that a homeowner wouldn't need to go through that process. Our extinguishers were hung on steel I-Beams throughout the factory and they vibrated from big punch presses and machinery running constantly. That seemed to pack everything tight.
/ Do fires extinguishers need to be shaken to prevent settling? #17
I have two outdoor extinguishers. One mounted on the outside shop wall, the other is attached to my ROP on the tractor. I keep an eye on the nozzles because mud daubers and other wasps like to pack them with material tight enough to prevent operation.
/ Do fires extinguishers need to be shaken to prevent settling? #18
The reason dry extinguishers pack is that the powder contained some moisture when filled. If the dry chemical is completely dry when filled, it will not pack. Most manufacturers have specs for the amount of moisture in the chemical. If the extinguisher is ever refilled locally, its probably defective.
/ Do fires extinguishers need to be shaken to prevent settling? #19
This is correct.
The problem is, we can never know for sure, unless you try to discharge it.
An important step to add the the instructions for a fire extinguisher, is: HOLD BREATH, BEFORE DISCHARGING.
Especially, if you are out of breath from running to get the extinguisher, and running back to use it, you could inhale some of the powder. The wind can also blow the powder back at you, when outdoors. If you do inhale the powder, you could be unable to properly fight the fire, as you cough your lungs out, for the next 10 minutes.
/ Do fires extinguishers need to be shaken to prevent settling? #20
I respectfully disagree. Almost all Fire Extinguishers are refilled and tested locally. I used to do it in High School, yes that was a long time ago, but is still done locally.
2018 Volvo VNL Truck, VIN # 4V4NC9EH0JN894705 (A61568)
2018 Volvo VNL...
2012 MACK CHU (PINNACLE) (A60736)
2012 MACK CHU...
2005 Suzuki King Quad 700 Fourwheeler (A61166)
2005 Suzuki King...
Galvanized 30' Floor Augers (A60463)
Galvanized 30'...
LMC Ag 3pt 300 Gallon 54' Boom Sprayer (A60462)
LMC Ag 3pt 300...
Bobcat A770 (A60462)
