YM226D Starter
   / YM226D Starter #11
"When it clicked, the radiator fan acted like it wanted to turn but it did not."
Can you turn the engine over by hand, and assure it is not seized?
   / YM226D Starter #12
Uh.Oh! 1000 dollar starter...
   / YM226D Starter #14
My point. Esp. how rare it would be locked up unknowingly to Norm. And more of a shady repair shop price. I honestly don't think that was for a starter even with labor included no matter how shady. Wrong repair ticket maybe? I don't know.
It's been 2 days and with it trying to turn over, Fan trying to move. He may have found the problem. If locked up I think we would of heard about it my now.
   / YM226D Starter #15
Did it have the same #of teeth on the Bendix. I have read hoye saying there were some that bolted up but tooth could was off and it would grind the flywheel.
   / YM226D Starter #16
Hoye lists a starter for our ym2000 for like $350 I was thinking. So I can see some stealership charging a markup of $50so on that starter they would charge $400. If it was in a hard to get to spot, like removing a loader or lots of side panels, charging diagnostics I can easily see them charging another $400 for a total of $800. And if it was a $400 or $500 starter it could be closer to that price.
I wouldn't pay that but I can see it. Some of these places have crazy labor prices.
   / YM226D Starter #17
I know what your saying and agree with some repair shops and taking advantage of a unknowing customer. Sure it happens. I know what a JD. setup with a frontier loader on it is like. Not an issue there. And they're expensive and know what other repairs cost. Were talking a foot or two clearance and I think only 3 bolts. The YM2000 that would be around 100$ a bolt. 2 mounting the starter and 2 Elec. And maybe a couple to get the loader out of the way. Wow! They don't stay in business that long. Again I think the poster found the problem. All he has done was checked the battery so IMHO bad cables, Bad/dirty Ground to the frame or actually to the battery. Not knowing just because the battery is clean but the cable connections to it are dirty. It's been a while for sure not hearing anything and it was that simple of a problem.
   / YM226D Starter #18
Yeah $1000 for our yanmar starters would be a screw job for sure.
I had an issue with my starter Bendix not jumping out. I took the solenoid most of the way off and put it back on and it's been fine for a year or so, I must have knocked loose some corrosion or fixed a bad connection in the process.
   / YM226D Starter #19
be very glad you don't own an LS tractor!. 'LS' Starter for U5020 & U5020C Tractors: Genuine 'LS' Part! and you can't find them cheaper!..
   / YM226D Starter #20
New/Unused AGT Air Compressor (A57454)
New/Unused AGT Air...
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
2003 PETERBUILT PB330 DUMP TRUCK (A58375)
2003 PETERBUILT...
207277 (A52708)
207277 (A52708)
16ft Driveway Entrance Gate with Tree of Life Design (A57454)
16ft Driveway...
2014 Freightliner 108SD Crane Truck, VIN # 1FVHG5CY3EHFL1495 (A57453)
2014 Freightliner...
