JD2210 Wheel Spacer bolt spacing
   / JD2210 Wheel Spacer bolt spacing #1
scsi2005
Maryland, USA
JD 2210, 60c deck, 260 Backhoe, 210 loader, JD 1023E 60 in. deck
Hello all,
I need some help.
I would like to buy a pair of wheel spacers 2"-2.5" for my JD2210. I am unable to locate the bolt spacing. I know it is 5 bolt but is 2.5" spacing correct. I know JD has wheel spacers but they are only 1".
I am after the 2"-2.5" because my property is on a hill and driving with the loader and backhoe on, sometimes I get the jitters on hills.
Thanks in advance
   / JD2210 Wheel Spacer bolt spacing #2
Bolt spacing is measured oddly.
Hook the end of your steel tape over the end of one bolt, stretch it to the third bolt, skip one, measure to the center of that bolt. That measurement is your bolt spacing.
I'm not with my 2210 right now. I'll try to remember to measure it when I get home this evening.
Thanks. If I measured it correctly then I have a 4.50. I was measuring it to the second bolt and thought it odd at 2 and a 1/8.
Thanks for the info.
Steve
Thanks Dale
Thanks Dale,
I checked their site and the only go up to 1.5" for my tractor.
Good site though.
Steve
FYI,
Some information which might be handy.
The JD2210 uses 7/16x3/4" lug nuts. Most wheel spacer sellers are 12mm or 1" lug bolts. Very hard to fine the correct match for this tractor.
Just some info.
Thanks
Steve
   / JD2210 Wheel Spacer bolt spacing #8
here's a utube how to measure wheel bolt spacing - Google Search
Thanks sir it helped a lot.
Steve
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
2002 New Holland TN75S 4X4 Loader Tractor (A51243)
2002 New Holland...
2022 MAXXD BD14 Heavy-Duty Dump Trailer with 14K GVWR and Tandem Axles (A51039)
2022 MAXXD BD14...
John Deere Quick Attach Bale Spear (A50514)
John Deere Quick...
(INOP) 2005 JCB 506C TELESCOPIC FORKLIFT (A50459)
(INOP) 2005 JCB...
2023 MAXXD TDX Drop-N-Load Trailer with Air Ride Suspension and Tilt Deck (A51039)
2023 MAXXD TDX...
