New shop build, Doneish but continuing shenanigans
/ New shop build, Doneish but continuing shenanigans #21
I'd have done the same thing in your shoes. I added $500 to the cost with my bathroom.
Was you able to use home septic/water?
My shop is 400' from the house, and about 40' lower elevation. So cannot just tap House water/septic. And septics are outrageous cost wise as are tap fees for water. So I just step out back if I gotta take a leak, or run up to house for #2
/ New shop build, Doneish but continuing shenanigans #22
My existing shop has it's own septic and dumps in my hayfield. Water T'd into an existing line.
My new shop sits beside my new house, 50ft apart. Sewer exits shop and runs past house to a lagoon. House T'd in as it went by. Water same way.
/ New shop build, Doneish but continuing shenanigans #23
400' is very doable for branching off water. For sewer, a small sewer pump up to your field is also doable. You can buy continuous 500' rolls of HDPE pipe for both your water and pumped sewer. This provides a leak free line with no joints.
/ New shop build, Doneish but continuing shenanigans #24
Sure, anything is doable. But not cost effective or practical
Still in a holding pattern somewhat, it won't stop raining... hard to work dirt when it's near liquid... I think it's rained 3" in the last week... Think I have the kit finalized, need to look into electrical and permitting, might put in for the kit to keep winter pricing in place but I think I only have a 6 month window for permitting or something.
Going to happen, I need a shop, I'm out of room and can't keep up with all my hobbies without the thing!
Gotta look what the permitting lady said about plumbing, a toilet and utility sink would go a long way in my world...
/ New shop build, Doneish but continuing shenanigans #26
You sound like me...HOWEVER, I ALWAYS keep a half of a roll of TP in a 3 lb. Folgers coffee can...just in case....BobG in VA
/ New shop build, Doneish but continuing shenanigans #27
I had to stop working for physical reason
Physically I am getting worse and my have to sell everything, too hard to take care of, real estate agent loves the place because a family owned business can down size and run there business out of here..... gets me that better nursing home:) we are not there yet, but we have the equity so we can pay cash for a nice house in town!
Truckdiagnostics, Probably really tough mentally to get rid of stuff but more importantly hopefully you stay healthy. Take care, Stanley
/ New shop build, Doneish but continuing shenanigans #28
If I was building a shop here is what I would use for the gray water, grease trap with bleeder lines for drainage. For the toilet I would use a electric one. like in the link.
Official Home of the Electric Incinerating ToiletIncinolet.com
/ New shop build, Doneish but continuing shenanigans #29
I just finished a 39x48x14. Heated slab. 4ftx10" footing. 6" floor. 2x6 stud on 2' C. Trusses every 4ft. 1ft eave overhang. 18" gable overhang. Panel liner ceiling. OSB wall liner. Batt wall insulation R19. Blown fiberglass ceiling R49. Conduit wiring. 200A service. LED 4ft ceiling lighting. 4 post lift. Two 12x12ft overheads. Two 36" walk-ins. Four 4x4 windows. 12'x8' bathroom containing sink, stool, floor heat hardware and air compressor.
Love the floor heat but as others have mentioned, takes diligent planning!!!! Friend of mine just finished a very large shop with one 4 post and three 2 post lifts. Drilled into two circuits of his floor heat setting the lifts. I'm using a Rinnai tankless water heater for source. Operates sinfully cheap.
Don't short yourself on lighting.
Don't short yourself on wiring of any kind.
Don't short yourself on insulation. Build a solid, tight building.
You'll get exactly what you invest into this building. Invest cheaply and you'll get a cheap building.
I have $42 per sq ft in my building.
Now you just need to add a lean to for that big yellow Ford TLB.
/ New shop build, Doneish but continuing shenanigans #30
Life always gets in the way...
I have the corners staked out, I've removed about 10" of dirt from the high end and a few inches from the low part, have a transit but need to get it closer to visibly flat before I get too carried away...
That said, the plans and inspections require no organic matter under the slab, and probably a good idea to remove top soil. The question is how important is it to get top soil out of the way? How much digging do I need to do? I'll be putting gravel under the slab, how deep?
I've been too busy to do research, using a 4000lb 26hp tractor with a 4' bucket, a 4' 5 tooth ripper and a 5' box scraper (no teeth) is not the fastest way to move dirt, and work has been taking up too much time... really need to get the permit process started but want to get the dirt work out of the way first so I have a better foundation started, pardon the pun...
/ New shop build, Doneish but continuing shenanigans #32
I removed all topsoil. Then hauled in clay. Got it within a couple inches of flat. Compacted with a sheepsfoot. Made my pad area a lot bigger than my building. Had 20ft of flat grade on all sides past edge of building. The builder said he'd add 12" of elevation with fill material, insulation and 6" slab.
Over estimate rather than under estimate. You only get one chance to build a good pad.
/ New shop build, Doneish but continuing shenanigans #33
You do not want water under you slab and any that does get there you want to drain away. Organic material expands when it gets wet. When we put in our pole building we dug out 400 yards of top soil and brought in stone. It is important. You mentioned one area is higher than the other, consider drain tile and clear stone on that edge. I have areas where we do not have the correct drainage under the concrete and it moves every year. We are on clay and it expands big time. Check how your neighbors others in your area have done it. A lot depends on you local conditions on what you can and can not do. What works for one person will not work for someone else. Up north where it is sand, you scrape off the top soil and pour a slab. When we moved down here building on clay was new to me, didn't check around and made mistakes. Check with people in your area that is the best way to go. just my :2cents:
Steve
/ New shop build, Doneish but continuing shenanigans #34
Be sure that you know what topsoil is and identify it properly. I've seen a lot of pictures on here of people removing material that was not topsoil. Topsoil is loam. It's the softer, organic type of dirt that does not compact and is decomposing. Here in East Texas, we do not have topsoil. We just scrape off the grass and start building up the pad with red clay. Do not remove any material that you don't have to. Compacting the new material is very difficult and time consuming.
Making a flat spot is much more difficult than I anticipated, and my tractor is undersized for the undertaking...
Over the summer I got a LOT of dirt moved with my tractor and got everything within 8" apparently (most within ~5") but going the rest of the way takes much more finesse... By far the most time sucking part is just moving dirt around and finding the right place to put it (I found many more low spots in my lawn than I thought I had...). The loader on my tractor is small (if you look up Kwik Way loaders, most are on garden tractors...) so it doesn't hold much dirt in the bucket and hauling that small amount 100 yards takes time, then you gotta get that dirt flat and harrowed, big time suck...
Anywho, my brother offered his Ford 4600 with loader for the weekend and his 48" 3 point tiller to put on my tractor, we spent about 4 hours and the area is expanded a little past the perimiter and all within 2" of being flat and all undisturbed under that level... tomorrow I get to move the 10ish yards of dirt that we dug up today then load the tractor and tiller back up...
I'll be ready for inspections and permitting soon finally! The rain hasn't started yet so I'll wait until that is over before I dig the holes for the posts, I believe the first inspection is for the holes...
As for the drainage concerns, the shop will be on the highest level of my property pretty much, I think I will be renting a trencher at some point to put in electrical and might as well put in some tile though. I believe the plans call for a bunch of gravel so there should be room for expansion. On the soil type apparently according to my brother there is some areas that are down to clay but some are topsoil, we dug out most of the less firm soil though so it should be reasonable.
/ New shop build, Doneish but continuing shenanigans #36
Easy to dig dirt, but it takes a lot to move it any distance.
When I've built pads, I rough it out by dumping the dirt from my bucket and back dragging it. I do this in every direction that I can get my tractor to go. After a few loads I get off the tractor and walk it. That will show my the most obvious areas that need more dirt. I try to get each layer a couple inches thick or less, and I drive over it with the bucket full to cover every inch to compact it with my front tires. Once I get it kind of there by eye, I get out my laser level and spray paint. I either go of the exactly spot I want it all to be, or I walk around and figure out where the most level spots are and put a dot there, and move over 4 feet and mark it plus or minus how many inches I need to change it. Every 4 feet, in every direction will get marked. Then I can get it really close from the seat by dumping and back dragging. It might take me 3 times of measuring to get it ready for concrete.
/ New shop build, Doneish but continuing shenanigans #37
Anybody can build a pad. Few can build a flat solid pad. It's an art.
/ New shop build, Doneish but continuing shenanigans #39
My 80x50 pad cost me 5000$. Done by a pro.
And if done properly it was worth every penny.
My wife and I built our pad 180x100, sheepsfoot packed, levell within 3", moved 1300 yds of dirt. Have no idea what it would have cost.
Here's some pictures of where I got to this summer and where I ended this weekend... The picture with the 4600 doing work is yesterday with my brother operating and the picture with the 4600 on the trailer is where I ended this weekend. Have the corners marked (the right posts might be hard to see, they have marking paint on the tops) and everything is within 2" and I have a big pile of dirt to figure out what to do with... I'll drag the transit out next weekend (need daylight, could borrow a laser level though...) to measure again but I imagine being within 2" is close enough, the gravel will need to be better but that's easier...
Seeing the corners marked I need to get the transitions on 3 sides a bit further away I'm guessing... How much space should I have flat away from the building? One of the short walls will be on the right of the picture, there's maybe an 18" rise over about 8'. The long wall toward where I took the picture tapers from floor level to that about 18" level and I have maybe a foot from the corners flat at most. I might be over thinking it though as this is just the lowest level, the plans call for 4" of 3/4" minus gravel under the slab and I'll likely be going with a 5" or 6" slab to use my 2 post lift so floor level will be 10" above that and probably a 4" thick gravel entrance for now...
2008 INTERNATIONAL MA025 FLATBED (A55745)
2008 INTERNATIONAL...
2011 Toro Workman HD Gas Utility Cart (A59228)
2011 Toro Workman...
2021 Honda Pioneer 700 4x4 Gas Utility Cart (A59228)
2021 Honda Pioneer...
2014 Bobcat T650 (A60462)
2014 Bobcat T650...
2023 GREAT DANE FLP-0024-00053 53FT FLATBED TRAILER (A59905)
2023 GREAT DANE...
Caterpillar 928G Articulated Wheel Loader (A59228)
Caterpillar 928G...
